3rd member install, need some help and advice
Old Oct 9, 2007 | 12:27 PM
neliconcept's Avatar
Yo everybody, just thought id post this up, I am at the final stage of my 4wd conversion and I need some help, dont have any space to install this and was wondering if anyone in the CO area could help me swap this out. I just got some ridiculous quotes from two shops here in foco for 290 to 313 and then pederson toyota insultes me by saying 600 for the swap. no joke on that either.
going from a 4.10 locked rear end to a 4.56 arb rear end.
anyways just thought id ask.
Old Oct 9, 2007 | 12:53 PM
Albuquerque Jim's Avatar
Is the 4.10 e-locked or lunch box? If lunch box, this install should be real easy. Pull the axles and swap the third.
You need: jack stands, 10mm wrench for the brake line, a 14mm for the 4 axle and drive shaft bolts, and a 12mm for the 3rd bolts. Run the air line, bleed the brakes, fill the diff and drive away. You may want to change the axle seals while you are at it.
Old Oct 9, 2007 | 12:55 PM
yeah its lunchbox.
thanks for the tip Jim, should help me prepare before doing this.
Old Oct 9, 2007 | 12:58 PM
881stGenRunner's Avatar
blake do you have a completely seperate rear 3rd? If so then install is a breeze. I gotten so good at mine, i can have one out and another in in about 1.5 hours thats due to unfortunate events i had ealier in the year.
Is the air line already run outside the diff? J/w. O and picking up the diff and putting it into the housing absolutely sucks
Old Oct 9, 2007 | 01:03 PM
its fully built, airline conection is already drilled into the third housing, basically I may just go buy a jack and stands and do it in the dorm parking lot.
Old Oct 9, 2007 | 01:05 PM
Right on, you shouldnt have any problems. Good Luck
Old Oct 9, 2007 | 01:11 PM
yeah but no fun without airtools, and i only have a 3/8s rachet. i need to get a breakerbar, and I dont know how to bleed the brakes.
Old Oct 9, 2007 | 01:14 PM
PoleVaulter95's Avatar
bleeding brakes is not a one person job unless you have a vacuum bleader. (im going to assume you dont) so make sure you have a friend handy
Old Oct 9, 2007 | 01:54 PM
Originally Posted by Ric
Blake,
your welcome to do it here, Ive got a few comference calls this afternoon/evening, but your welcome to the garage.
I know its a little drive Did ya ever get ahold of Anthony ?
nothing as of yet, left him a message.
i think its a little too late now, but maybe friday afternoon?
anybody know how many quarts of gear oil it will use?
Old Oct 9, 2007 | 02:19 PM
tc's Avatar
tc
Come on down. We'll be installing a CB with another guy on Friday night, 'wheeling on Saturday (see the trip planning section), but could do it on Sunday.
We have all the tools, and I've had mine in and out a few times - should only take a couple hours.
Old Oct 9, 2007 | 09:09 PM
Flygtenstein's Avatar
Do the seals while you are in there.
If you cannot bust these fasteners loose with a 3/8's ratchet, turn in your man card. Run CO2 for an air gun if you are in a parking lot and worried.
Brakes are easy.
Old Oct 10, 2007 | 03:33 AM
Bighead's Avatar
Blake, if you have any concerns with bleeding the brakes let me know and I'll send you the pdfs from the Factory Service Manual.
Old Oct 10, 2007 | 04:16 AM
3 quarts for the diff.
Old Oct 10, 2007 | 07:36 AM
44Runner's Avatar
A flare nut wrench in the right size will be nice too.
Honestly I sat here for a bit trying to figure out why he would need to bleed the brakes. Then I remembered, drum brakes, riiiiight, lol. I was thinking disc in my head.
Swapping thirds is no big deal. I wouldn't sweat it too much. I think I could swap a third in well under an hour. With help from one of these doods and the right tools it'll be a breeze. Good luck...
Old Oct 10, 2007 | 08:31 AM
thanks guys, hopefully me and Issac can get it knocked out pretty fast tomorrow, (if i can get off work)
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
bryan34w
Jul 6, 2015 05:53 PM
