3" lift with 33'' tires
Old Dec 4, 2008 | 03:20 PM
jmcgowan's Avatar
Originally Posted by 4Crawler
That's what I want to do with my 2WD 1994 Pickup. Can I fit 31X10.5 R15's with a 1.5 balljoint spacer front, and a rear shackle kit ? Will I also have to crank up the front torsion bars ?
How would I correct the speedo ?
subtracting in my head will not work, Arizona has speed cameras EVERYWHERE...
Old Dec 4, 2008 | 03:32 PM
4Crawler's Avatar
Probably will fit, check the clearance around your existing tires with a block cut to the added witch and height. So, for example if you had a 29x9.50 tire now, make a little block 1" wide and 1" tall and run that over the tread face and see where if might hit the wheel well. Then see if raising things up ~1.5" would eliminate that interference. May need to adjust the torsion bars to achieve the desired height (higher or lower) after installing the spacers and to level the truck:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ2
The best option for speedo recalibration with taller tires is to change the axle gearing to match the tire height. So existing-gear-ratio X 31/existing-tire-diameter = new-gear-ratio. Added benefit is you'll retain the current acceleration and gas mileage you now have. Second best is to hit up a speedometer shop and either get a recalibration gear box made (for a mechanical speedo) or Dakota Digital makes electronic speedo recalibration boxes. Or the speedometer itself can often be recalibrated at a speedo shop.
Old Dec 4, 2008 | 05:12 PM
tc's Avatar
tc
My '89 2WD had like 3-4" of lift (Fabtech IvanDan) and rubbed BAD with 31's
Old Dec 4, 2008 | 05:36 PM
phildelfino's Avatar
GPS devices have a screen or page that gives current data ( current position, altitude, current speed ). If you don't have one maybe get a used one. After changing tires sizes, it would be more accurate than your speedometer.
Old Dec 4, 2008 | 06:03 PM
  #25
VSU_4runnin's Avatar
ive gotten pulled over a few times for that and ive just explained that i got bigger tires.. theyh look and go ooh... and just say i forgot... but 5-8 miles over isnt alot.. unless in a school zone no cop is gonna pull you over for under 10
Old Dec 4, 2008 | 06:19 PM
  #26
RB Cam RB's Avatar
I rubbed really bad with the 31x10.5s even with 3.5" Spindles and 1.5" BJ Spacers in the front. Only after some trimming it all worked out.
Old Dec 4, 2008 | 07:15 PM
  #27
jmcgowan's Avatar
I have a GPS, but GPS theft is big here. If they see a circular mark on your windshield (from the GPS mount), they smash the windows to look for a GPS. I hate phoenix
Old Dec 4, 2008 | 07:18 PM
  #28
jmcgowan's Avatar
There are SPEED CAMERAS everywhere here. It's not a matter of talking to cops, it's a matter of getting tickets in the mail for $200. I hate Phoenix.
Old Dec 6, 2008 | 08:14 PM
  #29
jmcgowan's Avatar
I have a GPS, but GPS theft is big here. If they see a circular mark on your windshield, they smash the windows to look for a GPS. I hate phoenix
sorry for the thread jacking. I think I will just use my GPS for a while, without the windshield mount, I'm gonna velcro it in place of the incorrect speedo...solves both problems.
Old Dec 6, 2008 | 08:35 PM
  #30
sa51's Avatar
i'm pretty anti body lift unless its a 1 incher
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
