help with tire size
Old Dec 6, 2008 | 07:00 PM
afnf_life's Avatar
help with tire size
ok so im getting some fiberglass fenders and 1 inch body lift for my 93 4runner..
and my buddy was will to give me a set of 35 by 12.5 tires
do you guys think the fenders and body lift will give me enough clearance to fit those tires
Old Dec 6, 2008 | 09:53 PM
tc's Avatar
tc
I don't think 'glass and 1" BL will be enough for 35's
Old Dec 6, 2008 | 10:39 PM
stagger_lee's Avatar
You cant glass the rear. You mind barely clear up front, with lots of rubbing. I hope you don't plan on driving any thing other than in a straight line. No fenders up frint and sawzall the rear and you're golden.
Old Dec 6, 2008 | 11:28 PM
SpecialScottie's Avatar
Maybe with a 3 inch body lift with minimal rubbing if you really HAD to run the 35s
Old Dec 7, 2008 | 04:43 PM
afnf_life's Avatar
what i really wanna run is 33 by 12.5 would it clear those?? and im will 2 do a little bit of cutting in the rear if i had 2 if that would help any
Old Dec 7, 2008 | 07:12 PM
4rnr's Avatar
Your attacking it wrong. What rubs is the body seam. take off your tires and grab a 10lb sledge and go nuts on the foot wells. you will be able to fit 35's with stock fenders. I ran 35's with only cranked t-bars
Old Dec 7, 2008 | 07:23 PM
sa51's Avatar
i was just staring at my truck and thinking my 33s look too small, i could fit 35s if i break the hammer out.
but i think i'll wear these 33s out and save up for some 5.29s and arbs
Old Dec 7, 2008 | 07:52 PM
afnf_life's Avatar
wont takin a hammer 2 it mess stuff up lol
any pics of your runner with 35s
Old Dec 7, 2008 | 08:33 PM
sa51's Avatar
well you are just fixin what the factory messed up, hammer the pinch weld down. i had to do that to all my yoters
Old Dec 7, 2008 | 08:35 PM
afnf_life's Avatar
ok im really new 2 this so i might sound stupid.. what is the pinch weld??
Old Dec 7, 2008 | 08:38 PM
sa51's Avatar
its ok man we were all new once, take the plastic inner fenderwell out. behind it should be a piece of metal that looks like it was pinched together at the factory, i hammmered this flat on my taco and my 32s didnt rub.
Old Dec 7, 2008 | 08:42 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i can't find a picture on a toyota but here's a writeup with pics on a jeep. same idea
http://www.jeepsunlimited.com/forums...d.php?t=913120
note: you don't have to get as detailed with the body filler and sound deadening and stuff if you don't want to. a few whacks with a giant hammer and some paint should be the basics...anything more is added bonus
Old Dec 7, 2008 | 08:52 PM
afnf_life's Avatar
ok thanks guys that helps alot!
Old Dec 7, 2008 | 09:01 PM
sa51's Avatar
i also did this on my 95 and nothing rubs at all
until i put 35s under it lol
Old Dec 7, 2008 | 09:15 PM
33's will be very doable and functional for now until you get a bigger lift/gears. Still take care of that pinch weld to avoid any cutting/rubbing.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
