2wd wheels
Old Oct 24, 2009 | 02:54 PM
adams707's Avatar
2wd wheels
i have a 89 p/u 2wd that i just lifted and im putting 31x10.5s on some 15x7s but dont know what backspacing or offset i need, dont exactly know what either of those are but the wheels im looking at are 3.75 bs and -6mm offset. will these work?
Old Oct 24, 2009 | 03:15 PM
4Crawler's Avatar
Pull a wheel off (or lower your spacer) and measure the back spacing yourself then you will know:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
Old Oct 24, 2009 | 05:05 PM
adams707's Avatar
im running stock wheels right now so those wont tell me much
Old Oct 24, 2009 | 05:07 PM
4Crawler's Avatar
That will tell you what the stock backspacing is, that way you can compare your new wheels to the stock ones. Generally you want no more backspacing that stock, less will be wider track.
Old Oct 24, 2009 | 05:09 PM
adams707's Avatar
just measured and mine looks like 4.75 also...so would less backspacing make them stick out wider?
Old Oct 24, 2009 | 05:11 PM
adams707's Avatar
srry just seen your post after i posted mine, so what would you recomend for stock axles?
Old Oct 25, 2009 | 11:55 AM
4Crawler's Avatar
Yes:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Old Oct 27, 2009 | 03:06 PM
adams707's Avatar
ok well how much wider can my stock drivetrain handle? if i get some with 3.5" bs will it handle it?
Colington
Mar 8, 2020 09:51 AM
Up&Down
Aug 5, 2015 06:20 AM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
skoti89
Jul 6, 2015 07:45 PM
