dual cases getting hot.
Old Oct 29, 2009 | 08:04 PM
kinzer's Avatar
hey, put in a dual 4cyl transfer case set up in my truck. 2,28 23 spline in front case and 23 spline 4.70 in the rear case. when using the front case the shifter gets really hot. i figured this is normal because more gears are turning causing more friction, thus heat. but its getting really hot sometimes. does this happen to other dual casers? my fluid level is good too. and i installed the oil galleys and pump.
Old Oct 29, 2009 | 08:12 PM
tc's Avatar
tc
Mine gets pretty hot - you can feel the heat coming through the open hole in the floor (one of these days I need to get a shift boot ...).
Are you using dino oil? The lower friction of a synthetic might help.
Old Oct 29, 2009 | 08:20 PM
4Crawler's Avatar
Yep, mine do that, too. With conventional oil and driving at high speed for a long time, the levers are almost too hot to touch. With Redline synthetic, it is probably 10-20F cooler, still hot but not so much you can't touch the shifters.
Old Oct 29, 2009 | 08:25 PM
kinzer's Avatar
it mostly gets hot when using the low in the first case and in higher gears. id rather resort from synthetic, iv had way too many problems with this thing leaking. first was the v6 adapter plate didnt seal and i had to drop it all and re seal it, then the drive flanges were leaking, then the rear output housing. i think iv pretty much got a hold of the leaks, for now.
Old Oct 29, 2009 | 08:46 PM
4rnr's Avatar
it likely has more to do with heat coming through the floor now that you have cut it up. I have a large custom center console and I cant even touch it in the summer.
Old Oct 29, 2009 | 09:04 PM
kinzer's Avatar
actually no, the first case, the one getting hot, is in the stock location. and i have a boot covering the hole. which im pissed about because dr smash started making triple shifters again! after i cut the hole.
Old Oct 29, 2009 | 09:16 PM
waskillywabbit's Avatar
Mine get hot as hell. I need to cover the opening and put on some shift boots.
Old Oct 29, 2009 | 10:02 PM
kinzer's Avatar
Old Oct 30, 2009 | 12:19 AM
dropzone's Avatar
Fossilized
Mine get hot too but you might wanna separate the two cases and make sure that none of the oil passages are blocked.
I think that I will give the synthetic a try. The ice in a cup melts pretty quick in mine...
nice clean job on your install by the way..
Old Oct 30, 2009 | 01:02 AM
turboboost's Avatar
My single case even gets really hot when I use 4LO a lot on a long day of wheeling.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Daenerysdad
Oct 1, 2015 07:33 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
an1mal_69
Sep 8, 2015 09:40 AM
