loss
Old Oct 29, 2009 | 06:09 PM
my91Runner's Avatar
loss
This is my first toyota. I got a 91 4runner it is lifted 5" with 35" tires. Iy has a 4.3 Chevy in it with a turbo 350 trans. My question is it does not have steering stabilizers on it at all. When you go over a bumper it is all over the place. Would a stabilizer fix this problem. Also it has no sway bar on it. Is that normal?
Old Oct 29, 2009 | 06:10 PM
my91Runner's Avatar
Old Oct 29, 2009 | 08:41 PM
4rnr's Avatar
Pretty typical of a POS 5" IFS lift, especially if it has been driven around for....maybe a couple years, and has been wheeled.
Old Oct 30, 2009 | 11:03 AM
my91Runner's Avatar
So what to do to fix?
Old Oct 30, 2009 | 11:09 AM
4Crawler's Avatar
Well, you could start with checking for worn components; tie rod ends, idler arm, ball joints, etc. If that is all OK, try putting a steering stabilizer back on and some sway bars with extended end links to restore them to the stock orientation will probably be a good idea.
Old Oct 30, 2009 | 11:10 AM
muddpigg's Avatar
Trouble shoot the front end. Factory FSM will tell you how. so will the books, chilton/haynes.
Old Oct 30, 2009 | 11:11 AM
Wheelingnoob's Avatar
Get a steering stabilizer (probably not the problem but will help), chack the Idler arm for play (bet this is a problem) ball joints and TRE's. Those are the things that always made my truck feel loose and worn out. Each time I replaced them it was good till the next wheeling trip then it was idler arm busing time again.
Old Nov 1, 2009 | 08:55 PM
muddpigg's Avatar
I've got upper and lower ball joints if you find yourself in the market. Was going to replace mine but found a heck of a deal on a solid axle and decided not to put them on.
x2 part number K9587 amd x2 K9482
I chose Moog cause they were greasible. May an offer. I'm going to put them back in the classifieds so pm if interested.
Old Nov 3, 2009 | 04:55 PM
my91Runner's Avatar
Had a friend look at it. It has week leaf springs in the front. When you turn the tires you can see them flex and twist. I just have to find a place to get stock height springs for the front.
Old Nov 3, 2009 | 05:28 PM
whokrz's Avatar
It sounds like your 4runner has a solid axle swap. You probably have 48 inch springs in the front. They are measured eye to eye. You could probably make your own spring pack by removing and adding leafs until you have it like you want. It is hard to say with out seeing pictures of your suspension.
Make sure the leaf springs bolts and the u-bolts are tight. You could also check the wheel and trunnion bearings to make sure they are not loose.
Old Nov 3, 2009 | 05:35 PM
my91Runner's Avatar
I will take a picture in the morning. This is my first toyota so i have no clue on what is stock and what is not. So bare with me. Thank you all for your help.
puddlepirate
Jul 30, 2016 06:29 PM
shredder4286
Oct 1, 2015 01:09 PM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
charlie_fong
Sep 27, 2015 10:06 PM
