21 spline transfer case vs 23 spline
Old Feb 4, 2009 | 04:38 PM
88toypickup's Avatar
So I have been looking for a while and haven't really found an answer. Aside from the obvious, spine count, what is the difference between a 21 spline gear driven transfer case and a 23 spline gear driven transfer case? I keep reading about how the 23 spline is the strongest transfercase, but if the only difference between it and the 21 spline is the spline count then it can't be that much stronger.
Old Feb 4, 2009 | 04:48 PM
BigBluePile's Avatar
I think the main bearings are bigger.
Old Feb 4, 2009 | 05:05 PM
4rnr's Avatar
many people have done alot on the 21 spline stuff. There may not be a lot of info here on YT because frankly not many people here will ever find the limits of a 21spline. If you do a search on Pirate there is more info there but even there the general consensous is the 21spline stuff is tough. 42" tires, dual t-cases, many years at the hammers tough.
BTW the only reason I am running a 23spline chromoly is because thats what my cases came with.
Old Jan 23, 2015 | 12:38 PM
JaxAtttax's Avatar
anybody ever break one?
sorry for bringing up an old thread, again... Has anyone here actually experience breaking a 21 spline? or do people just get a 23 for peace of mind?
Old Jan 23, 2015 | 12:48 PM
AZkid's Avatar
I've seen it and its never pretty. 23 is definitely a piece of mind, but it really depends on what power plant you have, where you wheel, and mainly how you drive.
Old Jan 24, 2015 | 09:27 AM
muddpigg's Avatar
Thanks for using the search.....
Good post. To add to it depending on tranny output also. If your running a 23 spline tranny like from a turbo or v6 (R150/151) then it makes for easy setup.
As the v6 comes with a chain driven t-case and the gear driven is preferred.
Have seen builds with a 350 and a 21spline t-case. But that comes back to how the person drives.
Old Jan 28, 2015 | 09:46 AM
rattlewagon's Avatar
^ Agree. I think most of it is how the person drives.
Im going to 23 spline, because thats what I need to match up to my v6 trans.
Old Jan 28, 2015 | 10:05 AM
JasonYota's Avatar
^ Agree. I think most of it is how the person drives. Im going to 23 spline, because thats what I need to match up to my v6 trans.
Are you going to keep your R150 with the 4.3? I can't remember if I'm subscribed to your build.
Old Jan 28, 2015 | 10:24 AM
I dont think so. Will probably end up with a th350. But who really knows. Haha. Thats next winters project, well worry about it then.
Old May 5, 2017 | 10:28 AM
spddm0n's Avatar
Hey, what are you guys doing for companion flanges (yoke/flange) on the t-case? I just found that my front drive propeller doesn't actually match the 23 spline flange correctly? I'm wondering if there is an aftermarket multi-drilled flange somewhere. Trail Gear doesn't sell one for the 23 spline. I'm starting to wonder if my drive drive shaft isn't correct. The flange on the t-case doesn't line up properly with the flange on the front drive propeller. I checked a couple other drive props and they look identical to the one I have. ?? Not only is the bolt pattern not correct, the raised center ring on the drive prop flange (u-joint) doesn't fit inside the machined hole on the t-case flange.
Anyone else ever have this issue?
kawazx636
Oct 6, 2021 03:03 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
