2 inch roger brown
2 inch roger brown
i'm going to get a two inch roger brown from my 88 4runner 5spd. what brackets do i need to get (bumpers, radiator, steering linkage extension, shift linkage ext. etc) my front bumper in a smittybilt winch bumper and it says its good up to a 2 inch body lift so i think i'm good there. and i'm also planning to get new poly bushing. anything else i need?
thanks,
alan
thanks,
alan
i knew he was a man and i have been to the site but i was wonder if anyone in my situation has used his 2 inch BL and need the shift and steering linkage extension parts. Those are my main concerns.
Usually the steering extenison is not needed at 2", it can be installed but not totally needed, see the instructions:
http://www.4crawler.com/4x4/ForSale/...irculatingBall
Shifter extensions (assuming manual tranny) are purely cosmetic, if having the shift lever(s) 2" shorter (sunk into the floor) bothers (or will bother) you, then by all means get the extensions. If not, they will work just fine as is, assuming you do the proper clearancing around the shifter boots:
http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Other options available for the shifters as well including short throw kits, raised drivetrains, etc.
This is why I have the instructions on-line so that you can browse them and see what options might apply to you and your vehicle.
And you will see the "typical kits" listed for your vehicle on the web page:
http://www.4crawler.com/4x4/ForSale/...ift.shtml#GenI
The typical kit is what most folks "typically" need to lift that specific truck at any given height.
And yes, it is a 4Crawler Offroad Body Lift kit:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ12
live4soccer7
May 11, 2016 06:52 PM
kbpickens
Oct 2, 2015 03:37 PM
Brodetski
Sep 30, 2015 11:50 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
