1st gen lift is finished!! w/ pics
Old Jul 3, 2003 | 11:37 PM
descendents's Avatar
chevy 63" long springs in the back with mixed stock rear/stock front leaves in the front... no blocks, no longer shackles... time for new tires
heres a pic of 14" travel shocks + mounting
kelly
Old Jul 4, 2003 | 12:06 AM
metal22lica's Avatar
what size tires are you going to fit under here? 33s? 44s?
Old Jul 4, 2003 | 12:17 AM
im thinking about soem brand spanking new 35" mt/r's
quess its about time to change the avatar!
Old Jul 4, 2003 | 08:03 AM
Arnold's Avatar
It looks like you need a u-bolt flip kit for the rear springs too.
Old Jul 4, 2003 | 12:29 PM
yea i know i looked for one locally, right now i have the ubolts long enough so i can run a 1 inch block but im going to get a flip kit if i decide to run more than that.
kelly
Old Jul 4, 2003 | 01:32 PM
Shane's Avatar
those shocks look way too long...
Old Jul 4, 2003 | 06:56 PM
they wont be whne i throw an inch block on there... i designed them to run with a block
kelly
Old Jul 4, 2003 | 07:26 PM
joez's Avatar
ok, now, it appears that your double shackle in the rear is resting on the framerail. may i ask why? and if it is, did you put any kind of bumpstop on it?
Old Jul 4, 2003 | 07:49 PM
AznSky's Avatar
Look awesome kelly!! Hope you're havin fun back in az.
Old Jul 4, 2003 | 09:21 PM
yea that is the double shackle set up and its kiind of where the old hanger was... no bumpstop... whats wrong with how it is. it doesnt make any noise when i hit bumps so yea..
kelly
Old Jul 6, 2003 | 07:19 PM
bump stops
you dont need the bump stops on the double shackles, but it will quiet it down a lot when it folds back downafter being extented. I would suggest that you come up with some kind of bump stop to keep from bending the chevys where they will come in contact with the frame right behind the front mount.thats just my .02 since ive been there and done it.
Old Jul 6, 2003 | 07:29 PM
alright thanx for the advice
kelly
Old Jul 7, 2003 | 09:15 AM
jx94148's Avatar
My thoughts exactly. Looks like there is about 8 inches between frame and spring for available stuff but only 2 inches of shock left before it won't stuff anymore. Adding a 1 inch block will change that deficit to 3" rather than 2 but that still leaves 5 inches of lost stuff potential.
This current setup should droop for days but when one side droops the other needs to stuff just as much. This will lead to nearly all the weight carried by the rear axle going to the stuff side shock mounts.
I've got $2 on a shock mount being the first thing to break when you try to flex it. Any takers?
Old Jul 7, 2003 | 09:34 AM
Shane's Avatar
Shocks are at ~45°, so 1" of shock travel = 2" of suspension travel. Not quite that bad but I still think they will bottom out before the bumpstops hit.
Old Jul 7, 2003 | 12:43 PM
yes, shanes thinking is exact since they are at 45" angel 2" is = 1".... i can always remount them if i have a problem, but when i get new tires and throw an inch, inch 1/2 block in i think i'll be ok
kelly
Old Jul 7, 2003 | 12:51 PM
oh and btw those are the old bumpstops for the stock rear springs... not for the chevies
kelly
Old Jul 8, 2003 | 07:44 AM
02Runner's Avatar
Schweeeeeeeeet
justdifferentials
14
Jun 11, 2017 08:36 PM
voiddweller
53
Feb 1, 2016 05:46 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
Badfish740
Sep 4, 2015 04:21 AM
