1990 4runner upper control arm links
Old Nov 2, 2009 | 11:57 AM
1990IFS's Avatar
i have a 4" lifted 4runner coil springs in rear. i need to make adjustable upper links. The lift kit gave me relocation brackets to raise the upper links. should i not use the brackets? how long should the tubing be before the end links are in
Old Nov 2, 2009 | 06:11 PM
tc's Avatar
tc
Huh? Raising the axle end of the uppers is going to change the way the suspension works pretty dramatically. Got any pics of these brackets? How much does it raise them?
Why do you think you need to make adjustable links? (ie - what is wrong) Admittedly, the uppers are a weak point in the stock design IMHO.
Here's the link to my reworking of the rear 4 link:
https://www.yotatech.com/forums/f116...thread-153382/
What is your fabrication ability? Can you weld well enough to trust your life on it?
Old Nov 2, 2009 | 08:20 PM
1990IFS's Avatar
i need to tilt the axle back a little because of driveline vibration
Old Nov 2, 2009 | 08:22 PM
1990IFS's Avatar
allpro offroad used to sell what i am looking for but they have discontinued them
Old Nov 3, 2009 | 07:33 AM
4rnr's Avatar
your coils/coil-buckets wont be happy, and you may bind your shocks in more ways than one. You may also bind the Panhard. Basically...bad idea.
Old Nov 3, 2009 | 07:36 PM
tc's Avatar
tc
My guess is that you actually need to rotate it DOWN (ie - need longer uppers). The flanges at the tcase and pinion ends need to be EXACTLY parallel so that the vibes induced by the ujoint on one end are cancelled by the one on the other end.
The other option is to go to a double cardan driveshaft and point the diff directly towards the tcase output, but as 4rnr said, this will cause problems.
Old Nov 4, 2009 | 07:02 AM
4rnr's Avatar
Shorter uppers will rotate the axle "down".
Old Nov 4, 2009 | 02:06 PM
tc's Avatar
tc
Oops - yes, you are correct.
Old Nov 4, 2009 | 07:52 PM
4rnr's Avatar
i knew what you meant
Old Oct 23, 2011 | 01:15 PM
Pritchard's Avatar
did you ever find the links you need? Im looking for some too...about 1 inch longer than stock. if you didnt use the control arm relocation brackets I would buy them from you. let me know who sells them or if you want to sell your brackets
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
coryc85
Sep 9, 2015 06:24 AM
ptb12
Jul 5, 2015 01:49 PM
