15 inch wheels
Old Feb 2, 2009 | 10:06 AM
PMB0409's Avatar
15 inch wheels
I have a 1996 sr5 4runner I was thinking about putting some 15/10 inch wheels with 35/12.50/15 on it but have been told by a friend that the 15s will mess the gears and or strip them. what is yalls input on getting 15s ? or should i just keep my 16s?
Old Feb 2, 2009 | 10:17 AM
Ed H.'s Avatar
what gears?
Old Feb 2, 2009 | 10:30 AM
HazMat's Avatar
The wheels themselves will not mess up your gears. You can get 35 inch tires on 16 inch wheels too. it is the much larger tires that could put stress on the gears. Many on here drive with 35s but most of them regear also. Regearing can get pretty expensive if i am not mistaken. Depending on what motor you have you could probably get away with 33s on 15 inch rims. Just rememeber that if you are going with a wider tire that you need to take into account the amount of backspacing the wheel has. i have 32s on my truck and it has no problem pulling them around.
Old Feb 2, 2009 | 10:35 AM
INFINITY's Avatar
tire dia is the main thing. wheel dia dont mean jack.
hazmat hit it.
Old Feb 2, 2009 | 10:49 AM
BLKNBLU's Avatar
If your truck has 16's originally you will want to check to see if it also has upgraded/upsized brake calipers as well. This could prevent 15's from fitting. I'm not sure however, what years and trim levels had the differences in brake size. Just something you will want to verify before you spend your dough.
Old Feb 2, 2009 | 12:05 PM
PMB0409's Avatar
the motor is the 3.4L V6 and 4.10 greas and the wheels on it now are not the stock wheels they are lexus wheels.
Old Feb 2, 2009 | 01:42 PM
cadman's Avatar
Tacoma tire & wheel fitment info here:
http://tacomaterritory.com/wiki/inde...ma_Information
4Runners may or may not be the same.
Old Feb 2, 2009 | 04:56 PM
4rnr's Avatar
your friend is right!
your muffler bearings will not be able handle the 15's.
Old Feb 3, 2009 | 01:26 PM
RoBatt's Avatar
^^ beat me to it
Old Feb 3, 2009 | 03:12 PM
PMB0409's Avatar
should i change my blinker fluid when my muffler bearings go out? hahahaha thanks
Old Feb 3, 2009 | 03:29 PM
flashkl's Avatar
Not funny man. My friend's taco had a blinker fluid leak and he ran out while doing 80 on the freeway...he ended up having to get both legs amputated...
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Yotoder865
Jul 9, 2015 07:51 PM
