A wheel Warranty question
My truck is still under full-warranty, my question is, if one of my tires has a slow leak while the other 3 hold tight, would that be warranteeable or would the dealer have an obligation to at least investigate the problem?
I just called the service dept. and they said that they would have to investigate my wheel/tire and if it is due to a manufacturers defect then I'd be covered. In my case, I don't think I've hit anything with the tire/wheel like by offroading or curb scraping, it has just had a slow leak for a while now. I will bring it in and report back, has anyone else had any slow leaks with their aluminum 16" 5 spoke Toyota wheel/tire/BFG Rugged Trail tire combination?
you probably picked up a nail or something. I see that you live in Massachusetts. I work in a tire shop and a common problem I see is corrosion forming around the bead. Its just the nature of alloy rims. I doubt it is a rim. How much pressure has it been losing. DO NOT use fix a flat that stuff is horrible for your rims.
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
