99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
A wheel Warranty question
Old May 24, 2005 | 08:22 AM
Ben03's Avatar
My truck is still under full-warranty, my question is, if one of my tires has a slow leak while the other 3 hold tight, would that be warranteeable or would the dealer have an obligation to at least investigate the problem?
Old May 24, 2005 | 08:28 AM
Ben03's Avatar
I just called the service dept. and they said that they would have to investigate my wheel/tire and if it is due to a manufacturers defect then I'd be covered. In my case, I don't think I've hit anything with the tire/wheel like by offroading or curb scraping, it has just had a slow leak for a while now. I will bring it in and report back, has anyone else had any slow leaks with their aluminum 16" 5 spoke Toyota wheel/tire/BFG Rugged Trail tire combination?
Old Jun 6, 2005 | 08:30 PM
mkodish87's Avatar
you probably picked up a nail or something. I see that you live in Massachusetts. I work in a tire shop and a common problem I see is corrosion forming around the bead. Its just the nature of alloy rims. I doubt it is a rim. How much pressure has it been losing. DO NOT use fix a flat that stuff is horrible for your rims.
Old Jun 14, 2005 | 07:46 AM
Ben03's Avatar
How about . . .
. . . if I used that slime stuff, is that stuff as bad as fix-a-flat for my alloys?
Old Jul 1, 2005 | 09:08 AM
mkodish87's Avatar
Slime really wont hurt anything, the workse that will do is make a mess.
glowz825
Jan 25, 2022 09:28 AM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
