99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 23, 2016, 02:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Water Leak
Old Apr 13, 2005 | 09:16 AM
slowyota's Avatar
Water Leak
Anybody else expriencing a water leak on their Tundra? It seems like it's coming through the fresh air intake and then leaking on to the passenger side floorboard.
If so how did you go about fixing it? The truck is out of warranty..2000 with 68K miles.
Old Apr 15, 2005 | 04:33 PM
PartsMngr's Avatar
My money is on the windshield seal leaking. I had a windshield replaced in a car and 3 months later realized I had a soaked carpet on the passenger side. If you have had one replaced recently I would say that is definately your problem. Hope this helps.
Matt
Old Apr 19, 2005 | 06:28 PM
crisis's Avatar
Also keep in mind it could be a heater core, assuming they are in that area. I know they are placed in that area on other type vehicles.
Old Apr 20, 2005 | 05:40 AM
slowyota's Avatar
Thanks for the recommendation guys. But, I actually had Toyota look at it and apparently this is a recurring problem with Tundra's and some Tacoma's. They actually have a TSB..had Toyota fix it, according to the TSB and the leak is back. So the truck is on it's way back today..
The problem is the fresh-air intake, inbetween the windsheild and the hood..apparently Toyota didn't design a big enough drain on the truck, so the reservoir slowly fills with water until it overflows on to the carpet. Oh well, it's the only problem I've had with the truck, so I guess I should feel lucky.
Thanks again!
Old May 27, 2009 | 04:51 PM
micbeth1981's Avatar
Cool water leak
Thanks again!
if you turn on the recycle button will that close the fresh air duct and stop water from leaking?thanksmike
Old Aug 31, 2010 | 05:24 AM
anyway to stop water from leaking in on the passenger side of my tundra 2000
Old Sep 4, 2010 | 08:05 AM
martinfan30's Avatar
A plugged or pinched evaporator box drain tube will cause this too.
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Jonny246
Jul 12, 2015 04:51 AM
Avenged
Jul 9, 2015 07:55 AM
