99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 12:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
Tundra EFI 1 Fuse Problems!!
Old Aug 5, 2002 | 10:59 AM
kctopher's Avatar
Co-Founder/Administrator
Exclamation Tundra EFI 1 Fuse Problems!!
My Dad owns a 00 SR5 Tundra, completely STOCK, he is having a problem with the EFI 1 fuse blowing on start up.. He replaces it with the alike 15AMP fuse with the same results.. He sticks in a 20AMP fuse and it starts up just fine.. He has called the dealer and they (like always) dont have any clue..
Has anyone seen or heard of a problem like this?? If so, what is is ???
I know this is seems to be a small problem, but its the small problems that plague the mind with "what if's...."
Chris
Old Aug 6, 2002 | 11:41 AM
Mohamed's Avatar
So what happens when he uses a 20 AMP? Does it also blow?
I am not an electrician so I can't really help you on this but I know, essentially when a fuse blows too much current is flowing. In that case, did you clean the contacts when installing the new fuse, maybe some type of contamination is drawing more current ? Maybe the injector (if it's electronic) is drawing current because it's bad or the injector wiring is contaminated with something. If it's under warranty, try having the dealer replace the injector, that would be my best advice, but sorry I can't help you any more than that.
Old Aug 6, 2002 | 07:24 PM
Shane's Avatar
Something somewhere is drawing too much current, either a short or something else. You don't want to up the amperage of the fuse, it's a certain value for a reason and upping it can lead to electrical fires. Diagnosing the problem from here requires an electrical schematic of the system that that fuse powers, and lots of time spent disconnecting things here and there and re-testing to try and isolate the problem.
Old Aug 7, 2002 | 01:04 PM
kctopher's Avatar
Shane you were right on, the 20AMP fuse worked fine until yesterday morning and then it blew.. My Dad was like enough, he towed it to the dealer and they said the only thing on that circuit was the FI and the fuel pump, they said the fuel pump was working but faulty, because it required more juice to work properly it would trip the 15AMP.. Makes sense, but it will be about a week before the new FP comes in from Texas..
Thanks guys..
Chgris
Old Aug 7, 2002 | 01:09 PM
Shane's Avatar
Glad to hear you guys figured it out, electrical problems aren't fun.
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
dpridgeon3
Jul 9, 2015 01:18 PM
Suprarossa
Jul 6, 2015 05:21 AM
