99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Toyota T100 Turbo
Old Jun 20, 2005 | 08:54 PM
highdezman's Avatar
Toyota T100 Turbo
I finally did it my own T100 turbo
Old Jun 20, 2005 | 08:56 PM
OldSchoolSupra's Avatar
Toyota CT-26?
Old Jun 20, 2005 | 08:58 PM
highdezman's Avatar
yes I bought it off ebay
Old Jun 20, 2005 | 09:02 PM
haha nice... im a Supra owner, thats why i noticed that... have any details on the install? stats on your manifold, fuel, engine management etc?
Old Jun 20, 2005 | 09:07 PM
highdezman's Avatar
I made every thing myself It does not use any custom manifold and the fuel ecu is a urd ftc, and im going to install larger injectors and higher flow fuel pump. It took about a week to do and i have an intercooler below and in front of the truck.
Old Jun 20, 2005 | 09:11 PM
Does NOT use any custom manifold? Mind a further explanation?
That's awesome regardless.. hrm... i have an old CT, might be fun to fab onto the 22r haha
Old Jun 20, 2005 | 09:17 PM
Corbit's Avatar
How much boost can you push ? Are you still on the stock fuel map ?
Old Jun 20, 2005 | 09:29 PM
highdezman's Avatar
I made a platform for the turbo to sit on than ran the exhaust to it, and im currently editing the fuel map on my ftc ecu. I max out on cold nights at 10 psi.
Old Jun 21, 2005 | 12:34 AM
DudeBud's Avatar
sweet got any pics
Old Jun 21, 2005 | 05:40 AM
Bumpin' Yota's Avatar
how is the ct 26 working for you? At what rpm level do you start building boost and at what rpm are you into full boost by? Lastly near redline, does the boost fall off at all?
Old Jun 21, 2005 | 06:12 AM
94x4's Avatar
Guest
[QUOTE=highdezman]I made every thing myself "It does not use any custom manifold" and the fuel ecu is a urd ftc, and im going to install larger injectors and higher flow fuel pump. It took about a week to do and i have an intercooler below and in front of the truck.
Sound's familiar ?
Good going "highdezman", waiting for some pics on that.
Old Jun 21, 2005 | 11:49 AM
99_Runner's Avatar
Pics man, for the sake of all that's good and decent, post some pics. It's just not right to make all of us wait in anticipation of how this looks.
Then get it to the dyno or the strip so we can see some performance numbers.
Gotta give you some props for pulling this off. Especially in a week. Amazing, simply amazing.
Old Jun 21, 2005 | 11:55 AM
X-AWDriver's Avatar
Yes,close up pics of the turbo/exhaust connection if you want to call it that instead.
Old Jun 21, 2005 | 07:30 PM
highdezman's Avatar
The first thread has a picture of my engine I dont have any others yet, Boost starts around 2200 and builds to full boost around 3300 to 3500 and it does not fall off at high rpm it just keeps pullin, Im still working with the fuel system and With no cooperation from urd it is taking some time but im getting closer. Im putting in a larger fuel pump and injectors next week sometime.
Old Jun 21, 2005 | 07:33 PM
highdezman's Avatar
I cant take a pic of the turbo platform as it would require dissasembling the system to see it. Ill do the best i can soon.
Old Jun 21, 2005 | 07:44 PM
highdezman's Avatar
Smile
Ok here is another pic not pretty but what did you expect for a 500 dollar budget.
Old Jun 21, 2005 | 08:46 PM
AgRunner06's Avatar
Dude, that is kickass. Please follow with more details.
Awesome job.
Old Jun 22, 2005 | 11:10 AM
94x4's Avatar
Guest
Now that's working it, "highdez", and is what I'm talking about, but with a 2nd. gen V6...Look out.
Great install, you'll scare alot with that hookup, especially once you get it "tuned in".
Old Jun 22, 2005 | 11:19 AM
rimpainter.com's Avatar
I am confused...are you running the turbo off one bank? Or did you completely re-plumb the exhaust crossover to "collect" at the turbo?
Good idea on the fuel pump. I bet you are running crazy lean at a sustained 10psi.
Old Jun 24, 2005 | 06:10 AM
highdezman's Avatar
the down pipe was redirected to the turbo and the clamp you see, is in the event i need to replace the starter i can pull the header pipe down for easy access. Ill folow up more after5 i get my fuel pump in possibly this weekend.
