99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Apr 5, 2016, 09:33 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Cooling System Guides
Print Wikipost
Thermostat swap on 3.4L 2wd Tundra HELP!!!
Old Jun 25, 2012 | 09:20 PM
dsal_86Yota's Avatar
Went to swap thermostat on a wifes friends 03 Tundra 2wd 3.4L V6. I thought the thermostat was on the top of the engine but found out its not. Then she got the book and I found that its on the lower part of the engine. Anyone done this? Trying to help wifes friend save money. HELP PLEASE!!!!
Old Jun 26, 2012 | 05:07 AM
250000_yota's Avatar
Yes, it's pretty easy. Drain the coolant, remove the three nuts on the housing, remove thermostat. Replace with spring towards the engine, and the little jiggle valve pointing up. Reverse order of disassembly.
Old Jun 26, 2012 | 09:08 PM
Thanks. I got that part its the location of the thermostat on the 3.4L im having issues with
Old Jun 26, 2012 | 09:31 PM
Sorry, forgot to mention that this is on the lower radiator hose. You seem to be describing the upper hose.
Old Jun 26, 2012 | 09:48 PM
vital22re's Avatar
totally a bro
factory spec for the thermostat is jiggle valve at 6 o'clock. And yes you will need to unbolt the aluminum pipe that the lower hose goes to. 12mm socket and socket wrench will do it.
Old Jun 27, 2012 | 05:06 AM
Thanks guys. Will try to get on it this next week. Between the heat here and the fires not sure when I will get to it
1996Taco
Jul 20, 2015 12:02 AM
taller1
Jul 16, 2015 03:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Suprarossa
Jul 6, 2015 05:21 AM
