99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
are sounds ok??
Old Oct 23, 2004 | 11:33 AM
slyang1012's Avatar
are sounds ok??
Last night after work, i wanted to see if there were any sounds coming from my aals, so i went over a curb and as the tire hit the ground, split second later, i hear this ding which i believe was the rear aal. This morning when i went out to get some breakfast, everytime i stepped on the brakes going 5mph to a stop, i hear dings!! is this normal for a spacer and aal setup??
Old Oct 24, 2004 | 12:43 AM
slyang1012's Avatar
after work tonight, i listened carefully to the sounds and it sounds like shutters!!! Im thinking that it could be the ubolts holding the aals together.. maybe it got loose?... The tech installed the aal inbeetween the second leaf from top top and the third one(bottom) i will try to check first thing when i get a chance.. but what do u guys think??.. If it is loose.. is it bad to drive with it like that?
Old Oct 25, 2004 | 10:08 AM
BigA's Avatar
Sound to me like you need noisier tires or to turn up the radio try spraying some lube between the leaves. It might just be friction. If the u-bolts are loose you would know it because the thing would always make noise and handle funny. Also look at the leaves, is there an overload leaf that is not always touching the main leaf pack? It may just be swing up and hitting the main pack and making your noise.
Andrew
Old Oct 25, 2004 | 10:34 AM
slyang1012's Avatar
Andrew
THANKS~!!! I went back to the shop that had them installed.. and guess what?? The screw was there and everything holding it in place.. but there was no NUT bolting it down!!!!!!!!!
Old Oct 26, 2004 | 06:14 AM
BigA's Avatar
What was missing the nut? The spring pack or some of the U-bolts.
Andrew
Old Nov 7, 2004 | 12:48 PM
slyang1012's Avatar
the nuts were missing! so they found one that fit and bolted it! whew
:pat:
Davebarbier
Nov 3, 2015 03:28 PM
Kamaloha
Oct 16, 2015 05:13 PM
Chicken12
Oct 14, 2015 03:54 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Sep 28, 2015 11:21 PM
