99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
all with body lifts-quick reply
Old Feb 15, 2005 | 11:27 AM
slyang1012's Avatar
ok.. guys. im gonna get a body lift. For those who have body lifts for awhile now, how are they? is the ride different? does if feel like its giong to flip while turning?.. please give experiences. THANK!!! oh yeah.. is $550 too much for a body lift installed? thanks
Old Feb 15, 2005 | 03:20 PM
jacksonpt's Avatar
Senior Member
I've got a 2" BL on my 4Runner. Ride is no different, handling is only noticably different, but I don't drive it like a sports car. There is a bit more wind noise, and gas mileage is down just a bit.
Old Feb 15, 2005 | 03:47 PM
Yoter's Avatar
Guest
Say the body lift will cost you $150.
They want to charge you $550
You in my opinion would be overspending $400.
Its an easy job. set up a mod day and get a few helping hands to help you out.
Old Feb 15, 2005 | 04:05 PM
calrockx's Avatar
i can agree to that, though i have a 1.5" body lift.
don't pay someone to get install the body lift. i was a bit intimidated at first, but it's really not that complicated to install, just a bit tedious.
unbolt body mount bolts
hi-lift one side, use wood block to secure, install blocks. repeat on other side.
rebolt the mounts with spacers in place.
if you need to install a steering extension, that's a little tougher, but manageable. just gotta be a bit nimble. a 1.5"er is pretty simple.
Old Feb 15, 2005 | 04:08 PM
slyang1012's Avatar
man thanks guys! i guess i have to wait for my buddy to weld up some sliders for me! I think that will be easier using my hilift instead of the stock jacks. If i lift up the frame with the hilift.. how do i raise the body to put in the spacer?
Does the handling seem dangerous on turns eventhough your at low speeds?
Old Feb 15, 2005 | 04:17 PM
Kookadala's Avatar
You dont jack the frame at all, put a 2x4 under the door and jack that up to raise the body. Dont go any higher then the spacer sizes since you will be stretching brake lines, AC lines, etc. The hardest part is to modify the 4 by shifter and the tranny linkage (if auto), which needs some welding. I did the bed one day and then the cab on another day.
Handling has not changed from the body lift, but it has from the suspension lift. gas mileage sucks now.
Old Feb 15, 2005 | 04:19 PM
Good Times's Avatar
just use a floor jack and some jack stands. work from each side of the truck and you're set.
easy as apple pie. Should take no more than 2 hrs doing it all by hand and pee breaks
Old Feb 15, 2005 | 05:52 PM
jacksonpt's Avatar
Senior Member
Just to elaborate... it should take no longer than 2 hours to put in the blocks. If you decide to drop the radiator, put in a steering extension, etc., figure a bit more time.
Old Feb 15, 2005 | 05:55 PM
Yoter's Avatar
Guest
And dont thrash on the battery and radiator neck like I did. It just aint worth it.
Old Feb 16, 2005 | 05:35 AM
4Hummer's Avatar
2 Hours my BUTT. more like 2 days.
I did a 3" Lift. if you live anywhere that see salt. FORGET IT, every bolt is going to be siezed. Most of mine where, Plus the bolts were siezed into the metal sleeve inside the body mount.
If you in an area that see salt and stuff. BUY new poly body mounts, Than take a Saws all and silmpy cut the old body mount and bolt right off and toss em. install the new body mount and lift puck and your done.
I SPENT HOURS and HOURS and HOURS trying to get the old hardware off.
Also Get the Roger Brown Kit, its WAY Better in design and strengh than PA Kit.
Old Feb 16, 2005 | 08:19 AM
uboatcmndr's Avatar
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml Go here! Great education. You also might want to hold off with the slider install because a bodylift will move the body UP FURTHER and you may have an undesirable gap.
Old Feb 28, 2007 | 02:20 PM
ravencr's Avatar
Did you ever do it? If so any comments? Pics? What year Tundra do you have?
Chris
Old Feb 28, 2007 | 02:32 PM
MudHippy's Avatar
3" body lift, torsion bars full cranked, no sway-bar, 6"ish backspaced rims with 35x12.5's. My truck handles very good, no body roll in the curves to speak of. It doesn't feel "tippy", even way off camber, but it's probably due to my wheels stickin' out so far, around 4" or so. Working on my engine is my only complaint, neckache city.
4.34runner88
Jan 12, 2016 01:10 AM
Sep 4, 2015 09:27 AM
Foage3z
Florida
Aug 31, 2015 04:49 PM
bighaydn
Aug 4, 2015 07:17 PM
yourrealdad
Jul 21, 2015 11:13 AM
