99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Apr 5, 2016, 09:28 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Engine Guides
Print Wikipost
03 tundra
Old Jan 5, 2009 | 01:29 PM
catdaddy's Avatar
03 tundra
Should I have replaced the water pump, when I replaced the timing belt, and the serpentine belt? The dealer told me it wasn't nescessary. Kind of concerned now though. This is on a 03 tundra 4.7 v8
Old Jan 5, 2009 | 01:43 PM
Ed H.'s Avatar
i cant believe the dealer told you the truth, must be the last honest one, how many miles are on it? It kind of sucks now though the truck is all back together. maybe check some other forums or google it
Old Jan 5, 2009 | 01:46 PM
catdaddy's Avatar
I Have 98,000 miles on it now
Old Jan 5, 2009 | 01:55 PM
Godzilla's Avatar
Yes, I would have changed the water pump at the same time since it is pretty much right there and you will only be paying for the cost of the water pump.
It is a "damned if you do, damned if you dont" situation, if it is not leaking.
However, to avoid maintenace costs between your next timing belt, it is best to do so.
Old Jan 5, 2009 | 02:00 PM
catdaddy's Avatar
Yeah I asked the dealer, and they said there was a seal that they would replace if it looked bad. But I know on my old 89 extended cab, when i did the timing belt ,I did the Water pump too.
Old Jan 5, 2009 | 02:13 PM
Godzilla's Avatar
Yes, they are typically done together. You dont HAVE to. But general consensus is to do it at the same to save possible service costs. Also, the seal alone doesn't dictate the condition of the water pump, it just means its not leaking...yet.
Old Jan 5, 2009 | 02:33 PM
zlathim's Avatar
I replaced my t-belt on Saturday. My w/p was not leaking, but showed signs of seapage. I had 109,000 on mine so it was an easy decision to replace the w/p too.
Old Jan 5, 2009 | 02:39 PM
catdaddy's Avatar
Yeah I should have known better. I just hope that if and when the pump goes, it don't really mess up my engine. Then that dealer is gonna get a peice of my mind 4sure
Old Jan 5, 2009 | 05:23 PM
zlathim's Avatar
It won't mess up your engine as long as you don't let it overheat. When it starts to fail, it will likely start leaking and you will notice coolant under your rig. You have to really ignore it for serious trouble to come from a bad w/p usually.
justdifferentials
14
Jun 11, 2017 08:36 PM
ToyotaMD
Nov 9, 2015 11:53 AM
LCE_Performance
Oct 1, 2015 01:03 PM
beltcutter
Sep 30, 2015 06:14 AM
4runnerFireman
Sep 29, 2015 06:24 AM
