Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Landcruiser brakes making me crazy
Old Jul 18, 2005 | 08:52 PM
coloradosafaris's Avatar
I have a 95 Landcruiser and have just got the thing set up and ready to get out to the dirt. Problem is, I have been having problems getting correct power brake pressure. It has normal power brake feeling on regular driving but on downhill with a bit heavy pressure it is a very stiff pedal and difficult to stop. I did a new master cylinder, full bleed and just did all the pads but no luck? I also performed the test for the booster and all tested OK.
Any ideas? Please help. Thanks
Old Jul 20, 2005 | 10:31 AM
TRunner's Avatar
That sounds like a booster to me... What test did you do? It may be in a failing state where as when you tested it it was doing fine, but then will fail at other times.
chukarhunt
Dec 8, 2019 11:39 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
