Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
FJ80 axle questions
Old Jul 5, 2009 | 01:52 PM
99ncxj's Avatar
FJ80 axle questions
I'm wanting to learn everything i can about FJ80 Axles. I'm considering buying some for my Jeep XJ but don't know much about them. What are the strengths, weeknesses in them? Any certain years/types i should stay away from?
Old Jul 5, 2009 | 06:02 PM
Dan.3's Avatar
ih8mud.com
Old Jul 5, 2009 | 06:44 PM
99ncxj's Avatar
Originally Posted by BAMF_CT2004
ih8mud.com
Yea, thanks. I'm searching over there too. Just thought someone here might have some input on them.
Old Jul 27, 2009 | 04:43 PM
GarnerFJ40's Avatar
Go with the portaled Volvo axles....
Old Jul 27, 2009 | 06:13 PM
AxleIke's Avatar
What exactly did you want to know?
They are strong. 5" birf instead of the 3.5 in mini trucks. If you find the right years, the rears are Full Float with disk brakes. Should handle 37" tires stock just fine. To be safe, upgrade to longfields in front, and poly performance chromo shafts in the rear.
Both front and rear came with electric locking differentials on some models. Both front and rear have offset diffs to the passenger side. Meaning, if you have a center drop t-case, and you drive on the road, you are going to get driveline vibrations pretty bad if you use the rear axle. I can't remember what drop the XJ's are in the front, but I thought they were passenger.
63" WMS to WMS in the front, 62.5 in the rear, IIRC.
Front is a high pinion (30% stronger) 8" diff, rear is an 8.875" regular diff. The rear is really strong.
Front high steer can be done with OTT arms (require machining at OTT= have to send your knuckles out) and leaf springs. Slee high steer requires links as leafs will not fit. Figure 6-700 for the steering.
More can be found on IH8MUD, and Pirate.
Old Aug 13, 2009 | 08:32 PM
AxleIke's Avatar
Jeep used FJ80 axles? Find that pretty hard to believe.
Old Aug 14, 2009 | 08:27 PM
AxleIke's Avatar
Cool!
I'm always eager to learn new things. For my own amusement and piqued curiosity, would you mind sending me a few links so I can learn more?
Thanks!
Old Apr 17, 2011 | 01:30 PM
Lc80series's Avatar
Great axles. Set up for coil springs. Full floating. Some even came with e locked differential from the factory.
Old Apr 25, 2011 | 02:27 PM
Lost's Avatar
consider the rear is centered and the front diff is on the pass side,
Old Apr 25, 2011 | 02:36 PM
jrobertson4runnner's Avatar
why not just get an FJ80 and wheel that??
Old Apr 25, 2011 | 02:40 PM
Lost's Avatar
x2 jeep suck and break all the time
Old Apr 25, 2011 | 04:24 PM
AxleIke's Avatar
Originally Posted by Lost
consider the rear is NOT centered and the front diff is on the pass side,
Fixed it for you.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
