Nitro Gear Packages - 1 part number for both axles!
Old Nov 21, 2014 | 04:17 PM
justdifferentials's Avatar
Nitro Gear packages for your vehicle, now with 1 part number!
Nitro Gear and Axle has led the way for many innovating R&P and axle packages. Now they have simplified the way you purchase gears. With one part number you can purchase your front and rear ring and pinions, master install kits, solid preload spacers, and new yokes if they are required. No more searching around to find the correct install kits and ratios for both your axles!
Do you really need new gears in your axles?
It is a common misconception that Re-Gearing a vehicle is only for Hardcore Off-roaders or for huge oversized tires. In fact, most of the late model vehicles we produce aftermarket ratio’s for are daily driven vehicles with slightly oversized tires. In an effort to improve fuel economy, Late model overdrive transmissions are geared very high which means RPM’s are very low on the highway. When even a slightly taller tire is installed the RPM’s are reduced below acceptable levels that the engine was designed to run. This causes constant shifting out of overdrive, sluggish acceleration, poor economy and rapid wear on the transmission and other components.
By changing the Ring & Pinions in your vehicles differentials, you can match the ratio to the tire size to bring the RPM’s back to where the manufacturer intended. Typically it is recommended to select a ratio slightly lower (higher numerically) than what the math will tell you. This will help accommodate increased rolling resistance, wind drag, and added weight of aftermarket accessories and gear.
If you have any questions or need a quote, contact us
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
Chooch
Jun 19, 2015 03:05 PM
TheManOutside
Jun 18, 2015 03:32 PM
