Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
87 22R ignition issues
Old Apr 11, 2015 | 06:35 PM
JS1990's Avatar
I have a 1987 Toyota pickup, 2wd with the 22R motor (carbureted). I was driving my truck down the highway and was at a redlight, as I went to leave the light engine died while releasing clutch. The engine turns over but will not start. Made sure all grounds are good, replaced the cap and rotor, spark plugs and spark plug wires, the distributor pickup coil, the main coil and also the ignition control module. Engine sounds like it wants to start but won't turn over. Tried push starting and tried with starting fluid. Does anyone have any ideas?
Old Apr 11, 2015 | 07:21 PM
Mr.Utah's Avatar
Did the starting fluid do anything?
Old Apr 11, 2015 | 07:22 PM
JS1990's Avatar
Not at all, it got closer to starting on its own will
Mr.Utah's Avatar
You did check your fuel right?
Old Apr 11, 2015 | 07:23 PM
JS1990's Avatar
Yeah, I am getting fuel. Also checked all my relays and fuses. Checked any visible wiring as well and is all ok
Old Apr 11, 2015 | 07:24 PM
Mr.Utah's Avatar
If it sounded like it was going to start better with the starting fluid, I would check/replace fuel filter.
Old Apr 11, 2015 | 07:25 PM
Mr.Utah's Avatar
Has it ever died before like this
Old Apr 11, 2015 | 07:26 PM
JS1990's Avatar
Yeah it seemed closer to starting when I just let it do its own thing. But will check fuel systems tomorrow to verify. I'm pretty certain its some small electrical issue with something, but am definitely open to any suggestions
Old Apr 11, 2015 | 07:27 PM
JS1990's Avatar
Negative
Old Apr 11, 2015 | 07:33 PM
Mr.Utah's Avatar
It could be a number of things. Fuel, air, spark. It could also be vacuum related, check and make sure your vacuum lines are on, there is a whole nest of them. A bad distributor can also cause the sudden death (this happened to me). Inspect air cleaner and carb and float bowl.
Old Apr 11, 2015 | 07:36 PM
JS1990's Avatar
Thanks, the suggestions are much appreciated! I will put some more work into the trouble and see if an issue can be found
Old Apr 13, 2015 | 08:16 PM
Mr.Utah's Avatar
Did you get it resolved?
Old Apr 13, 2015 | 08:25 PM
JS1990's Avatar
Unfortunately not yet. I have to wait until Wednesday in order to try a new distributor. Everything else however seems fine
Old Apr 13, 2015 | 08:35 PM
Mr.Utah's Avatar
Well, if you lived here in Vegas I would give you one.
Old Apr 13, 2015 | 08:40 PM
JS1990's Avatar
Right on man I appreciate that. I actually have a spare, but it goes on a efi motor and for that reason obviously won't work with the engine in my truck. Luckily they aren't too expensive. I should be able to know by Wednesday night if that is gonna do the trick. Getting down there to the last bit of hope before I start stripping it down and going over it inch by inch
MO transplant
Apr 23, 2023 11:58 AM
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
94whiterunner
Jul 12, 2015 07:15 PM
cars-guy
Jul 11, 2015 07:51 PM
