Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
2wd rear-end strength
Old Dec 5, 2011 | 11:17 AM
black89t's Avatar
Originally Posted by JamesD
You do not need a V6 third. Since you are going to put a different differential and gears, a 4 cylinder housing will hold up just fine. Also the 2wd 3.07 3rd member is a dedicated 3rd meaning you cannot regear it due to the offset pinion so that housing is scrap. My advice is to put a Ford 8.8 in the back since parts are plentiful, cheap, huge aftermarket and they are way stronger than an 8" Toyota rearend. Heck you can probably find a Ford 9" if you are serious.
James
well i got this rear end out of a 91 2wd v6. i forgot to look at the code to see what gear ratio it has so yesterday i pulled the 3rd and it has 3.42's. also it has an abs sensor if that means anything. the main reason i wanted a v6 third is because i thought the mk3 supra diff only fits in the v6 third. or am i mistaken on that? and i don't want to do a 8.8 because of the extra weight and hassle to get it in there. i already have a custom ds and don't want to pay for another one. plus i feel confident that this will hold up. the 2wd v6 axles are significantly larger all around.
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
