Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Mojave tribute build
Old Apr 21, 2015 | 04:08 PM
  #41
slacker's Avatar
hahaha .. I have more people going ... whaaaatt on the engine color then anything else .. love it !
guess you'll have to wait and see just what I'm talkin' 'bout
Old Apr 22, 2015 | 07:21 AM
  #42
kawazx636's Avatar
I think it will look fancy! But I think it would look better with 24K gold flake! Go big or go home!!
Old Apr 22, 2015 | 04:57 PM
  #43
slacker's Avatar
yeah ... no ! hahahahah
Old Apr 24, 2015 | 04:30 PM
  #44
slacker's Avatar
C-3PO's cousin
Old Apr 29, 2015 | 04:31 PM
  #45
slacker's Avatar
Joel still workin' on the frame ... almost ready !!
Old Apr 30, 2015 | 10:23 AM
  #46
kawazx636's Avatar
You sticking with the IFS or going SA? Please say IFS so I know that you are still a Toyota purist... :o) Doing my frame was perhaps the most annoying part of my build! The entire frame was thoroughly covered with that nasty tar-like undercoating that was popular around here in the late 80's/early 90's. Talk about a major PITA to remove!!!
Old Apr 30, 2015 | 11:27 AM
  #47
Terrys87's Avatar
I wondered how you did yours. I do the same thing. Getting in all the nooks and crannies takes a while but about the only way I know of doing it with out blasting it. Drive train looks great.
Old Apr 30, 2015 | 04:10 PM
  #48
slacker's Avatar
yep , sticking with the IFS ... I do have a new IFS suspension lift going in though , but yep , IFS
this is not the way I do it normally do it ... usually I start with a bare frame , sand blast it , and go from there . My trekker I didn't sandblast , but it was a real nice , nice frame to start with . I really wasn't planning to go this far , but I just cant seem to come to terms with just letting the "little things" go .. I seem to need to fix them ... I think I have some sort of disease or phobia
  #49
slacker's Avatar
Joel has been a huge help on this .. and to keep up with him today we had to mount the tranny and engine to get the positioning for the new mounts .
I used some round tube I had , worked out great ...
Old May 2, 2015 | 03:41 PM
  #50
slacker's Avatar
engine and tranny back out .. time to finish up the frame .
and front end reduced to just a pile of parts
and with a little more work we're almost ready for the POR15 treatment
Old May 3, 2015 | 04:56 PM
  #51
slacker's Avatar
ok , so now we're done with the fitting of the engine .. time to make it perdy
first I started with removing the pan .. for those whom don't know , the original oil pan and pick up on the 5Vzfe wont fit this application . so as you saw in the previous pictures , I already powder coated the pan I need ..
With the pan off , I can now drill the new dipstick location .. and install the new holder
installed with a little red LOCKTITE just for "piece of mind"
also removed the "front end" to replace with all new parts
new oil pump , water pump , timing belt , bearings ect .......
Old May 4, 2015 | 07:23 AM
  #52
kawazx636's Avatar
Are those "cheater marks" on the cam gears that I see so you don't have to re-do the timing later?? Just kidding, I do the same thing!!! HAHA! I hate having to re-time dual cams!
I really need to get some of that chrome powder to give it a whirl! That stuff looks really good - makes the gold pop really nice too! I particularly like how it looks more like polished and cleared aluminum than it does chrome (or at least that his how it come across in the pictures)
Old May 4, 2015 | 04:09 PM
  #53
slacker's Avatar
of course ....
I ordered some clear coat for the chrome powder , suppose to make it look more like chrome . I was kind of going for a gold and silver look , on these , and I think I have achieved exactly that ? I'm really happy with the colors , and I think it's going to go great with the brown engine bay color and exterior
Old May 4, 2015 | 05:23 PM
  #54
slacker's Avatar
frame is all "prepped" now ... acid etched and washed
wheeled it into the shop , and all prepped for tomorrow
should be black tomorrow
Old May 5, 2015 | 03:11 PM
  #55
Terrys87's Avatar
You do have every nut and bolt out of that frame. You are making some quick work on this truck.
Old May 5, 2015 | 04:56 PM
  #56
slacker's Avatar
yepers ...
Old May 5, 2015 | 05:02 PM
  #57
slacker's Avatar
check this out
[YOUTUBE]
[/YOUTUBE]
Old May 5, 2015 | 05:09 PM
  #58
slacker's Avatar
done and curing overnight
Joel spraying , and I used the pressure pot to do the inside of the frame
and the "machine" cleaning the front diff ..
Old May 7, 2015 | 04:13 PM
  #59
slacker's Avatar
got the rear in .. just loosely , nothing torqued yet
blasted the front A arms , and some powder and new bushings
started installing the new lift , and got the front diff in place
Old May 8, 2015 | 05:49 PM
  #60
slacker's Avatar
little more today ..
still working on the front lift , so got the crossmembers , shocks , sway bar , axles , and a few other things
also checked the rear harness for damage , and re wrapped
POR15'ing the frame , you need to remove all the "lock" clips , so this is what I use to lock the harness into place
straps not yet tightened , as I may need to move the harness one way or the other
