Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old Jul 22, 2008 | 08:18 PM
  #141
shaw_j's Avatar
Lookin good!
Old Jul 22, 2008 | 09:48 PM
  #142
CJM's Avatar
CJM
Whats with the rear shock setup?
Old Jul 23, 2008 | 06:47 AM
  #143
slacker's Avatar
Originally Posted by shaw_j
Lookin good!
thanks ..
you havent been reading and following along !!!
they are "kicker shocks" , because of the spring blocks , they will control spring wrap .
Old Jul 25, 2008 | 07:39 AM
  #144
gittinit's Avatar
I hate to be the one to break the news, but shocks, don't controll anything. Shocks are made for dapening whether used in a standard configuration, or mounted sideways like a stabelizer. IMO You wasted your money. You could have bought a antiwrap bar to do the job correctly for what ya spent on that setup.
Old Jul 26, 2008 | 06:23 AM
  #145
slacker's Avatar
your exactly right .. it will dampen/control the spring wrap .. it wont be "harsh" like a traction bar .. personally , I like that better.
I ran them for 12 years on my old rig , and they worked just fine .. so I know I didnt "waste" any money . but hey , everyone has an opinion , and there all welcome .
Old Jul 26, 2008 | 07:02 AM
  #146
Sked's Avatar
I get massive amounts of spring wrap which im trying to fix. Ive been thinking of AAL to cure it but i want to see if this idea works. Anyways keep up the good work and maybe ill see this Trekker one day
Old Jul 27, 2008 | 01:16 PM
  #147
Jay351's Avatar
Take off the shocks boots!
Old Jul 27, 2008 | 03:04 PM
  #148
slacker's Avatar
Nope .. to bad so sad , I like em !
Old Jul 27, 2008 | 03:44 PM
  #149
CJM's Avatar
CJM
I cant read everything.. I see now, good idea!
Old Jul 27, 2008 | 05:27 PM
  #150
slacker's Avatar
I know it's a long post .. but seriously ..
read it ... and share your opinions !!! I'm interested !!!
little bit of a "lull" now .. as i'm going to be stripping a 2000 runner for the dash components and also the original 83 Trekker for the Body ..
Old Jul 28, 2008 | 05:42 AM
  #151
Squiddy's Avatar
Said it before, say it again .... great work!
Old Jul 28, 2008 | 05:48 AM
  #152
Red_Chili's Avatar
Anti-wrap half leaf is the best means of control, short of fabricating a torque rod (which would be the absolute best). Half a leaf (fairly stiff), top of pack, extending from the u-bolt plate forward almost to the front spring hanger, held at the front by a spring clamp available from any NAPA etc.
Old Jul 30, 2008 | 04:40 PM
  #153
slacker's Avatar
so not much to add today .. but a bit ..
dropped the engine back in place , and started on the transmission .. and clutch .
blasted the fork to check for cracks and such .. , and then zinc'd
on this swap , you will need to use the 3.0L throwout bearing ..
greased the fork , and inner bearing surface , and installed .
installed the pilot bearing ..
the 3.4L clutch installed ..
with these kits you get a "goofy" plastic alignment tool .. but I like to use my own .. an original input shaft .
and finally the tranny back in place ..
also mounted the starter ..
on the bottom mount of the 3.0L belhousing .. it is threaded .. so is the starter .. you I had to drill the threads on the starter so the bolt would go threw
very simple
Old Aug 5, 2008 | 04:22 PM
  #154
slacker's Avatar
re & re'd the ATM wire harness , for the MTM harness ..
also installed the front shaft .. had to remove the transfer flange because it has 10mm GRD11 studs , and stock 83 is 8mm .. so same as the rear shaft , I had to drill .
also mounted the front of the exhaust again , to get ready to build the rear ehaust pipes , and muffler ..
also fully mounted the fuel tank , and installed senders , and pump for good ..
I think thats it ..
Old Aug 8, 2008 | 06:18 PM
  #155
t-dogsyota's Avatar
flat cam causing no power and carb backfiring?
i posted here a few times before with my 83 22r with a new head that idles great sounds nice but!!!!!!!!
it shoots gas out the carb and runs like crap...it wont even move!
but purrs and starts up great!(cold start)
WTF
ive been through wires plugs roter cap and parts every timing adjustment ik can think of...OMG drivin me nuts
again help that works gets free beer..
thanks
Old Aug 8, 2008 | 06:31 PM
  #156
slacker's Avatar
WTF
thanks
sounds like timing to me .. but dude ..
you need to start your own "NEW POST"
Old Aug 9, 2008 | 02:55 PM
  #157
slacker's Avatar
thought i'd post some progress pics ..
as of today Aug 9th 2008
just working on the "plumbing" getting the fuel lines bent up .. , almost done .
Old Aug 12, 2008 | 04:49 PM
  #158
pwd's Avatar
pwd
Dam, another reason I love this site, the BUILDS! Looks like your doing an amazing job, I especially love all the rust-proofing, as I know what salt does to metal. I envy all your skill and care in your work, this is gonna be one awesome Toyota.
Old Aug 13, 2008 | 04:30 PM
  #159
slacker's Avatar
thank you for your kind words .. It's been lots of work so far ...
going to go slow for a while now , as I have to tear down the original Trekker for the body ..
Old Aug 15, 2008 | 04:22 PM
  #160
Ty's Avatar
Ty
wow, i love all the work your doing. I have the 22re out of my 94 pickup and im going to paint the chassis and rebuild the motor. Im debating whether to use the por15 or the rustoleum. That por15 stuff isnt cheap, how much paint did you use to paint the chassis? Also, have any experience with the rustoleum?
Love the build, i cant wait to see it finished =]
