Toyota Fiberglass: 1983 Trekker Build-Up Thread
#485
#486
finally got the fan controler mounted and wired .. I decided to go with the Flex-a-lite controler .. it will work from 60% to 100% depending on temp. .. + if necessary , it will run 30 seconds longer after vehicle has been shut off .
also .. got my new shoes
315/75R16 's .. (35 X 12.50 16)
#488
so continuing working on brackets for mounting "items" got the rear heater mounted
also working on the wiring ...
made brackets and mounted the computer , routed wires , and "tying" the harness for final loom ..
also started on the dash ...
because of the larger 2000 4Runner speedo , the left ball vent would not fit .. so I first cut out the old , and started to tack in the new .. Thanks Paul .. (donated the piece to the project)
#491
#492
so couple of things today ...
started machining a new antenna mast mount .. I know some might call it silly .. I just think it's all in the small details ..
you can see the old ones in the picture .. and neither nor really fit the new 2000 POWER antenna .. and because the fender is "flat" on the top where the antenna sits , the newer power antenna mounts dont fit either , they sit on the side of the fender .. in the picture .. the chrome stock piece is only a 1/2 .. the picture only shows 1 side .. I think it looked dumb , so this is why I'm making one .
so I started this .. still more polishing to do .
also decided to mock up the headlamp doors ...
and continued working on the dash
First I made a template for the original "woodgrain" , out of paper ... layed it onto some steel , and cut it out ... test fit
then I cut a tab or edging and welded
trimed and drilled ... and screw'd into place ....
Now I have a bare template for heater controles and switches , and sterio ... I'm not a smoker , so there will be NO ash trey in this unit !!!
and .. as this day was ending ... I decided to tape off the dash , and lay some tin foil on the dash .. in prep for fiberglassing a new "base plate" for the new dash pad ...
and a first layer of mat
#496
My NEXT build post on yotatech
and NO .. not repoping dashes !!! just another 1 off .
now why would you say that ? ... dude , seriously , I'm just a regular guy .. If I can do it , so can you !
just do it .
#497
yep .. I'm sure she was jealous .. she was raped of her tires & wheels and just dropped on the suspension , sitting out in the compound so she was looking a little ragged there over the winter .. I ended up picking up some other "rollers" , so at least now I can get her back in to the shop . (dang thieves)
i'm super excited to get onto this build .. it's been a long time .
yes .. I can get you exact measurements of the heater .
#500
Originally Posted by ocdropzone
oH forgot: Can you get me measurements of the 4Runner rear heater? I am thinking I might put one in the back for the kiddos to encourge their attendance on winter runs...the two times we went in feb and march they whined a little bit...
Robb - you'll need 15" X 10" X 6" to fit .
