FJ Cruiser (Build-Up Section) Post your build-ups here
Corey's 2007 FJ Cruiser Build-Up Thread
Old Aug 10, 2007 | 02:20 PM
  #161
Corey's Avatar
Co-Founder/Administrator
Gorillas installed 8-10-2007
Attention if you have black aftermarket wheels:
When I had the new wheels and tires installed yesterweek, they did not have any black Gorilla locks.
They had to special order these for me in a set of 5 so I could do the spare tire too.
These are acorn lugnuts like the others on there now.
If you have aftermarket wheels that use the acorn style of lugnut, here is the part number for a set of 5 black locks.
71631NBC
http://www.gorilla-auto.com/products...image=5713.jpg
Same size as the lugs, 12mm x 1.50.
They do not list the part number on their website since these were a special order.
I am also going to start keeping my torque wrench in the rig to keep these torqued all the lugs torqued properly.
They torqued them to 100 lb which I believe is correct for Toyota wheels.
I would have to look it up in my manual, but that is what they do Toyotas to.
Old Aug 11, 2007 | 06:48 AM
  #162
mbisson's Avatar
I think they should be 82-85 lbs. Those may be a little tight.
Old Aug 11, 2007 | 06:54 AM
  #163
Corey's Avatar
That is what I am thinking too.
I think last week the guy torqued the lugs to 85, will recheck them later.
Old Aug 23, 2007 | 09:13 AM
  #164
Corey's Avatar
Fourtrek's Hi-Lift mount relocated to ARB 8-23-2007
Several months back I bought Luke's mounts to secure the Hi-Lift to the factory rack.
Info can be found on that in this thread.
I wanted to see how the rig will handle on mountain roads by taking the Hi-Lift off of the roof and putting it up front on the ARB bumper.
I thought I needed 2" rings, but when I got those they were to big.
Luke sent me out a smaller 1 7/8" set of rings before I even got the 2" one in the mail to ship back to him.
Luke is a stand up guy.
Member CactusJK from the fjcruiserforums had the same problem, and he confirmed last week with me the 1 7/8" would work.
This morning I pulled the mounts off the 1 3/4" rings on my rack, and put the new rings on the ARB bumper.
Good fit!
A little gap, but it tightens down great.
I had to angle the mounts up a tad to clear part of the ARB bumper, and I also have to run it with the foot in the upper position.
If down like I ran it before, there are bolts on it that hits the bumper.
I got a nice scratch on the bumper when test fitting it
Below are a few pics of the install.
A shot from inside the cab.
The Hi-Lift will not interfere with my line of sight.
A shot showing just the mounts.
I may end up taking those shiny knobs off before they end up in some kid's collection.
Kind of like when kid's steal chrome valve stems.
Been there before...
Now I just run black rubber caps all the time.
I am anxious to see how it rides now on the mountain road I drive when I go up to Greenwater where I wheel.
PS...
I moved the rings all the way out to within 1/8" of the vertical bars on the bumper.
A little more stability, plus I am able to run the jack with the foot and WabFab mount facing down now on either side of the bumper.
It looks even better than it did this morning.
No pics yet of the reinstall.
Old Aug 24, 2007 | 10:29 AM
  #165
Corey's Avatar
Slight update
I moved the Fourtrek rings out to within about 1/8" of the vertical bars on the bumper.
If you do this, you will not even have to measure first, the Hi-Lift should fit right onto it.
This also lets the foot hang in the down position now, and if your Hi-Lift is sportin' a WabFab Sliderz Adaptor like mine, it will not stick up in the air like in my previous post.
It looks a lot better this way.
Old Aug 24, 2007 | 05:17 PM
  #166
BT17R's Avatar
Much better with it flipped down. I was worried that it could've snagged something and rotated into the hood. Awesome, lookin' very expedition ready!
Old Aug 24, 2007 | 05:28 PM
  #167
Corey's Avatar
Thanks Bob.
My neighbor below me works as a mechanic at Auburn RV.
I just found out they have outfitted a FJ Cruiser there before with a roof top tent.
They carry a very well known brand, the Autohome brand.
http://auburnrv.com/autohomepictures.htm
Same brand that Wayne put up on his roof.
I like the one piece shell type that just cranks straight up.
Easier than the type that flips over into a tent.
I may stop there and see what the Maggiolina Airland one goes for in a medium size.
I think that is what Wayne put on his.
Old Aug 24, 2007 | 05:41 PM
  #168
BT17R's Avatar
Nice looking, though I'd exceed the factory rack 175 lb. limit by a bit.
Old Aug 24, 2007 | 06:07 PM
  #169
Corey's Avatar
The unit itself weighs in at 128 lb, but from what I have read, it is the factory crossbars that have a 150 lb limit.
The unit itself is mounted to Yakima crossbars that span the width of the rack, and the rack can support much more weight according to Wayne.
I am going to stop by the shop tomorrow, as his wife just told me they do indeed stock them there, and may be closing out the 07 models.
Old Aug 25, 2007 | 06:09 AM
  #170
BT17R's Avatar
After reading through the links, I want one! Maybe next Spring. I'm wondering where the ladder is stowed when driving? Is there some way to lock it to the rack?
Old Aug 25, 2007 | 06:45 AM
  #171
Corey's Avatar
The alloy ladder stores inside the capsule, pretty cool.
Now the only problem I would have with it is...
How in the heck will this old man heft it up there and off?
I have room in my home to store it when not using it.
By looking at Wayne's pics, I may even be able to leave the Forutrek shovel/ax mount where it is.
I am glad I moved the Hi-Lift off though.
I will have to think about this mod Bob.
It would be cool though to just head up to the mountains for the day, then setup camp and crank 'er up.
Old Aug 27, 2007 | 04:54 AM
  #172
Corey's Avatar
Drove into work this morning with the Hi-Lift on the bumper for a road test.
Could not even tell it was on there except for the rattle.
I hear it rattling more now along with the sliderz adaptor than I did when it was on the roof rack.
Will have to work on eliminating that with some material.
I have seen others do it.
Old Sep 3, 2007 | 09:11 PM
  #173
RockAndRoll's Avatar
Dude, your crusier is really sick, if you check it out Ill post a sick tacoma we did that wheel on, killer rim from Procomp, I dig your FJ, now lets see some pics of you getting it in that bad boy!!. Larter Jared@rockandrolloffroad....
Old Sep 4, 2007 | 12:38 AM
  #174
Corey's Avatar
Thanks Jarad, I have never been so excited before about building up a rig.
It is a lot of fun.
Wait until you see the next major mod coming before to long.
I think the next time I will have an opportunity to get off road may not be until the Fall Colors Run in October.
Yeah, put up a thread on that Tacoma over in the Tacoma section so we can check it out.
Old Sep 14, 2007 | 06:40 PM
  #175
Corey's Avatar
HalGuard HG250R fire extinguisher installed 9-14-2007
Saw this mentioned on fjcruiserforums.com website in a search for fire extinguishers.
The nice thing about the HalGuard system is it is a "premium clean agent" which means it will not corrode like a dry chemical fire extinguisher can.
You can spray this stuff under your hood, under your dash, even your home computer and it is not suppose to short circuit or corrode anything.
Here is some info from their website:
HalGuard? is no ordinary fire extinguisher.
It contains an electrically non-conductive"clean" extinguishing agent that rapidly turns into a gas.
The clean agent used in HalGuard? has passed extensive testing by Underwriters Laboratories, and meets FAA requirements.
It can be found on commercial aircraft, and is used by airport fire fighters and on the flight line.
Hand held HalGuard? extinguishers are available in either compact 1.4 lb. and 2.5 lb. sizes, or larger 5 lb., 11 lb., and 15.5 lb. units.
The larger sizes are USCG approved, and meet DOT requirements for the heavy duty truck market.
65 lb., and 150 lb. wheeled HalGuard? extinguishers offer maximum clean agent protection for the pit lane or large facilities.
Their website
The HR250R (chrome available if ya wanna shine )
* No thermal shock to electronics
* No mess or damage to vehicle or surfaces
* Liquefied gas extinguishes hard-to-reach fires
* Does not impair operator's vision
* EPA approved
* Listed and rated 2B:C by Underwriters Laboratories
* Rechargeable
* Made in U.S.A.
* 2-strap mounting bracket
* 6' - 10' discharge range
* High quality steel cylinders
* All metal valve construction
* Compact, lightweight, easy to use
* One year limited warranty
I drilled 4 holes into my Powertank bracket and bolted the HalGuard mount to it.
I may raise it up to the next higher position, have not decided yet.
I also have to test fit the ARB fridge tomorrow to make sure it clears the bottle.
I am pretty sure it will.
I have a few other areas where I could remount it, one would be the face of the middle drawer of my cargobox.
Already had it positioned there, and the drawers will all open fine.
I bought this from a reseller, they have many listed on their site.
More than likely you will also get charged a $20 hazardous shipping fee, and it has to come ground.
They do not ship these on aircraft.
Old Sep 16, 2007 | 12:00 PM
  #176
Corey's Avatar
Kidde fire extinguisher added 9-16-2007
I added the Kidde dry chemical one to the plastic lift off tray in the back.
Used a few stainless bolts and nuts, the same ones that held it onto my Husky floormats when they were in the 4Runner.
The Kidde will be used for outside fires not rig related since it is a dry chemical unit.
Old Oct 3, 2007 | 03:08 PM
  #177
Corey's Avatar
Total Chaos Fab upper control arms installed, 10-2-2007
Upon having the FJ Cruiser lifted late last year, I noticed a bit of wandering at highway speeds.
This happens to 2005 + Tacoma users too, not just FJ Cruisers.
Upon researching the Internet (wonderful thing that thing be) I learned problem can often be traced to the caster being to high for the alignment.
The stock upper control arms often do not give enough adjustment when dialing in the caster.
I checked on Total Chaos Fab's website, and saw that is what they say.
When aftermarket lifts are installed on these model vehicles the OEM suspension design looses caster.
By altering the factory caster, the vehicle will lose on road handling & performance and has a tendency to wander when driving down the road.
TC developed the UCAs to add caster to the suspension when aftermarket coil over shocks and other lifts are installed.
This will increases overall handling and aids in the alignment of the vehicle.
These new arms also eliminate the ball joints as they utilize what is known as uniball technology.
You can see in my alignment chart from the other day that the caster was to high, not within specs.
With the addition of the new control arms, the alignment is now within specs.
I had my local Toyota dealer install these while I was at work.
They were happy to do it, as they realize they may be getting more requests from lifted FJ Cruiser owners.
I really wanted to see how they improved the ride on the freeway coming home from work today, but alas I was bucking high winds, and the FJ was getting tossed around a bit.
I will have to wait for a much calmer day to get a feel how much the ride has improved with the addition of these.
They sure do look nice though
Old Oct 3, 2007 | 03:57 PM
  #178
Toddski's Avatar
Very nice. Did it feel any different on the way home?
Gonna have to take it off a sweet jump now
So, whats your next project? ;-)
Old Oct 3, 2007 | 04:21 PM
  #179
Corey's Avatar
To windy to tell Todd, I was fighting some strong winds at 1:30 this afternoon on the commute home.
Next project coming up very soon...
BlueTorch Fab dual battery box
Painless 250 Amp Dual Battery Current Control System
Bought from Jegs
And this is going in the box.
Might have it all done late Saturday.
If so, pics by Sunday, that is if it gets done.
Old Oct 5, 2007 | 03:36 PM
  #180
Corey's Avatar
Total Chaos update
Just a quick update on the Total Chaos upper control arms.
Drove home from work two days in a row, and the rig is a different well behaved animal at highway speeds.
Not a super huge difference, but I no longer wander around, so I do not have to keep making course directions.
Before it was like sailing the Queen Mary at freeway speeds sometimes.
Now it tracks a lot straighter.
Ride is still not perfectly smooth, but that can chalked up to the aggressive tread pattern of the Dick Cepek Mountaincat tires.
If you are lifted and experiencing the wandering syndrome, I would recommend looking into these.
