Early Land Cruisers (Build-Up Section) Post your build-ups here
85 fj60 Build Thread
Old Sep 29, 2014 | 01:15 PM
secondhandstoke's Avatar
Hey guys, so this truck right here is my dad's, we scored it off a guy who had it stolen. These guys rolled it down the hill, after breaking the back passenger window. Apparently they then tried to start it to no avail, even after pouring gas in the carb haha serves them right.(Oh and another thing, they left two pretty sweet jerry cans too!) Anyway we got it for dirt cheap and all it needs is a new fuel pump, smog pump, a few new brake lines, back passenger window and some general TLC. Currently sitting in my dads driveway, hasn’t moved under its own power in a year and a half however, he has started it after replacing with stock mechanical fuel pump.
PO had gotten a dent in door as well as tailgate, and replaced both with rusty stuff? We were all like WTF? so we got both barely dented unrusty doors from the guy.
Some shots of the engine bay:
So my dad just recently started doing repairs on weekends, heres a few photos of the progress:
Crank Pulley off: 85 fj60 Build Thread-kqiubnb.jpg
Pulley bolt and 45 mm socket:
Camshaft and crank timing gears:
Crank pulley, water pump and replacement:
Fan:
Smog pump:
Timing Gear cover (needed a new gasket and seal around crank, to be painted with high heat primer and high gloss high heat): 85 fj60 Build Thread-aguevbf.jpg
That’s all, until next time..
Secondhand
Old Sep 29, 2014 | 04:26 PM
rattlewagon's Avatar
Great looking cruiser!
Old Sep 29, 2014 | 07:01 PM
Thanks Rattle!
Old Oct 17, 2014 | 05:01 PM
Update!
Alright so my pops got the water pump in, smog pump in (used modified ford smogpump) Timing cover, crank pulley, radiator, shroud, fan and AC condensor on:
Attached Thumbnails 85 fj60 Build Thread-crankpulley.jpg   85 fj60 Build Thread-smogpump-right-waterpump-left-.jpg   85 fj60 Build Thread-timinggearcover.jpg
Old Oct 17, 2014 | 05:13 PM
Heres a few pics with the fan and belts on (green line or something; made by Gates). All that is left is to put oil, coolant, and upper and lower radiator hoses. He will be reman. a leaky power steering pump (new seals and bushings, and new bearing for the pulley as the old bearing seized up) and replacing all vaccuum hoses everwhere! One thing that I thought I would share was about the Smog pump, the hoses that came with it weren't the right size, he needed a inside diam 0f 7/8. He was hard pressed to find that size in anything other than coolant hosing, so he found a shop that does hoses for all kinds of stuff, hydraulics, etc etc. The hose he got is oil and gas resistant, and it is like steel braided or steel banded and then covered with rubber, sort of like how tires are made. Anyway he had to use a mitre saw to cut it, and the wire inside messed up his wire cutters! so you know that is some tough hose.(15$ a foot it better be).
Attached Thumbnails 85 fj60 Build Thread-waterpump-top-smog-right-timinggearcover-crankpulley-bottom-.jpg   85 fj60 Build Thread-img_1246.jpg   85 fj60 Build Thread-img_1247.jpg
Old Oct 17, 2014 | 05:16 PM
Alright and one last picture, he will be finished with the coolant hoses and the fluids and what not by the end of the weekend, so Ill try and post up a quick video of this beast running!
Old Jan 9, 2015 | 06:26 AM
stkybgr's Avatar
Very nice FJ60. Do have any updates?
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
young buck
18
Aug 27, 2018 02:40 PM
priest16
15
Aug 6, 2015 07:43 AM
thefishguy77
Jul 30, 2015 10:59 AM
