scuba's 1999 Tacoma Build-Up Thread
Old Jan 20, 2012 | 06:35 PM
  #621
ChefYota4x4's Avatar
WOW, regarding the pulley,.....that's crazy!
Good news on the twin shifter.... hope it makes your experience out there much better, as is the plan
KOH?
Old Jan 20, 2012 | 06:46 PM
  #622
habanero's Avatar
Karaoke On Horseback.
Thanks for the ps pump write-up....I've got a feeling it's in the cards.
Old Jan 20, 2012 | 07:14 PM
  #623
RMA's Avatar
RMA
might not have been a bad idea to put the washer /spacer on the outside of the new pulley to hold the pulley down a little better .. but looks like the parts are just getting made thinner and thinner(cheaper).. good luck ! I wish i could go to KOH this year!!
Old Jan 20, 2012 | 07:16 PM
  #624
DeathCougar's Avatar
Originally Posted by scuba
It's back together. Had my neighbor help me get proper, and much looser, tension on the belts than before. New issue has seemed to arise, though.
Looks to be a wobble in the power steering pump pulley at idle. It does seem to smooth out a bit once above idle. But it looks like my next project will be replacing the bearing for the pulley shaft.
Video demonstrating the wobble.
http://www.youtube.com/watch?v=0tqi_YUq6NE
It isn't the bearing. The pulley is bent. Very common issue with the 3RZ/2RZ when its overtightened. If you can find a pump assy with a good pulley, I would just replaced the pump assy and be done with it.
Old Jan 20, 2012 | 08:53 PM
  #625
scuba's Avatar
KOH?
Lol, king of the hammers.
No problem. I didn't even need to do it, but it's done now.
I actually did use the spacer on the outside. I also used liberal amounts of blue locktite on the little bolts and torqued them down properly.
Thanks for the info buddy!
Old Jan 20, 2012 | 11:48 PM
  #626
yotaman85's Avatar
Wow man, your truck has come along pretty good. I'm really diggin' it. Looks like your steering/front end is starting to see its limits on a regular basis now, good stuff.
One of the best parts about your truck (imho) is how low it sits. How low will you be able to stay with the SAS and HS? I hope its not too much higher then now.
And again, excellent truck and good work man.
Old Jan 20, 2012 | 11:51 PM
  #627
dropzone's Avatar
Fossilized
I purchased a twin stick shifter today.
I'm getting tired of the hard steering while on the trail due to the front locker.
This will be a nice addition, that's for sure.
http://www.davezoffroadperformance.c...ifter-288.html
I'm hoping to have it installed by KOH.
another Convert
Old Jan 21, 2012 | 06:11 AM
  #628
scuba's Avatar
I'm deff starting to get to the limits. It's fun though.
The truck is deff pretty low for what it is. Since there haven't been too many people using the TG Tacoma SAS kit, I'm not too sure how low it will stay. I think it will get tall but settle down to be maybe an inch or two taller than now.
I may be getting a new job soon, if so, SAS progress will speed up, a lot.
And thank you for the compliments.
Originally Posted by dropzone
another Convert
Lol convert? I guess so
Old Jan 27, 2012 | 01:50 PM
  #629
scuba's Avatar
The prettiness came in today. I won't have a chance to install it until Sunday the 5th.
Needless to say it's going to sit on my dresser so I can stare at it the whole time. Hope my girlfriend doesn't mind.
Old Jan 27, 2012 | 05:40 PM
  #630
PismoJoe's Avatar
Ehl ya
Old Jan 27, 2012 | 07:17 PM
  #631
KOH(King Of Hammers), ....CHECKED it off in my 'newb' booklet! hahaha.
Hope things are well, Scoob!
  #632
PS> SICK Twin Stick!
Old Jan 29, 2012 | 08:20 PM
  #633
scuba's Avatar
Lol, thanks mark.
Twin stick install comes Saturday.
A sneak preview of what is to come.
Old Feb 1, 2012 | 05:00 PM
  #634
scuba's Avatar
So since no one got the hint from the above post ill just say it. Truck is getting a camouflage paint job within the next month or so. I found a company that produces spray cans that are supposed to match federal military colors.
They have a few different color greens and I'm not sure which I'm gonna use. The can on the top is from the sample in the pic above. I think I like the color that is on the bottom left can in the following picture. Opinions?
Old Feb 1, 2012 | 05:44 PM
  #635
Ahhh.
I've been out, first I'd seen that...... Camo, eh?
Got a stencil kit of cut outs made already?
Old Feb 1, 2012 | 06:00 PM
  #636
iamsuprman13's Avatar
Eh...you know, I am not really a fan of the military pattern camo for the trucks...but maybe that is because I am forced to see them EVERY day...but just the same I am tired of seeing all the all tan trucks...lmao, if it done right I think it should look really good...and knowing you scoob it will probably look amazing, or you'll fix it!
Old Feb 1, 2012 | 06:04 PM
  #637
yotaman85's Avatar
try to get tricky and do some digi camo.... two sticks one taco sounds pretty good to me
Old Feb 1, 2012 | 08:02 PM
  #638
scuba's Avatar
I don't have stencils or anything. It will be free handed. I work on a marine base so I see the camo patterns and splotches every day. I've got ideas for design and whatnot.
Old Feb 1, 2012 | 09:57 PM
  #639
RMP8080's Avatar
Just make sure you remember where you park it in the woods, or you may not find it later. Lol...
Old Mar 1, 2012 | 07:01 PM
  #640
rattlewagon's Avatar
You paint that bad boy yet?
