PismoJoe's 2002 Tacoma Build-Up
Old May 17, 2011 | 06:07 PM
PismoJoe's Avatar
Hey guys! Welcome to my Tacoma Build Thread
The truck is a 2002 Tacoma, 3RZ-FE, 5 Spd., 4WD, SR5
I bought this truck stock in late 2006, and since then I have been working on turning it into a capable rig.
Current Specs
Suspension/Steering
-Total Chaos 4WD Long Travel Kit
-Total Chaos Coil Bucket Gussets
-Total Chaos Spindle Gussets
-Total Chaos Heim Joint Steering
-Icon 9" x 2.5" Diameter Coil Overs
-Icon 9" x 2.5" Diameter 2-Tube Bypass Secondaries
-Icon 18" x 2.5" Diameter 4-Tube Bypass secondaries (2 compression tubes)
-Deaver F62 Leaf Pack with CCP shackles and hangers
Body
-Central Coast Prerunners Front Engine Cage
-Central Coast Prerunners Aluminum Paneled Wheel Wells
-Central Coast Prerunners Front Bumper/Rear Bumper/Bedside Supports
-Glassworks Fiberglass Hood, Fenders, Bedsides
-3 Baja Designs 8" LaPaz HID Lights (2 Driving, 1 Pencil)
-Front Wheel Tub
-Crown Steel Braided & Extended Brake Lines F&R
-Black Grille/Corer Marker Light Swap
-Painted in 2012 By Sierra Auto Body (Stock Color 040)
-15x8 MT Classic Locks
-33x10.5 BFG All Terrains
-Odyssey Battery
-Craftsman low-pro Aluminum Racing Jack
-Powertank with X-Flo valve upgrade
-Full size spare w/ mount that is completely removable
Drivetrain
-Stock 3RZ
-W59 Transmission
-Factory E-Locker Swapped
-Modified Tundra Front Axles
-4.88 Gears
-Manual Hub Conversion
-K&N FIPK Intake
-Flowmaster 40 Series, Cut & Dumped
-Toyota Parts ALWAYS used for repairs
Interior
-10" JL Audio Stealthbox
-Sony CDX-M9900
-Sony 500 Watt Single Channel Amp (Sub)
-Lanzar 1200 Watt 4 Channel Amp (F&R Speakers)
-JBL 3-Way Speakers F&R With Crossovers
-Digital Power Capacitor
-Otherwise Stock
I believe this is the earliest picture that I have, before the Deaver J59's and bilsteins. Somehwere I have a few when it was stock, but I think they are still on an old phone somewhere.
After driving the truck for about 10k, my head was done. The PO did not do the valve adjustments at 60k, so at 110k, it was time for a new head.
Shortly after, my pressure plate took a dump. New clutch FTW!!
Now that the truck is driving well, I turned my attention to what I always wished my truck had: an E-Locker.
I lucked out and found front and rear 4.56 thirds (code 04, w/ rear e-locker) at a local auto salvage yard.
Swap Swap time! I went in on a parts truck with a friend of mine, a 2000 tacoma with the TRD package. He wanted the motor, I just wanted the axle housing and wiring to make the swap easier.
Prepping the parts truck
BAM!
Swap Swap!!
Every TRD tacoma, 95.5-04 has the 4.10 R&P. This is removed in order to install my salvage yard 4.56 e-locker third.
4.10's coming out (with the switch intact cough cough Logan )
Axle housing prepped for FIPG and 4.56 third
New Axle Seals installed, lubed with seal glide and ready for axle installation
Now, for the wiring. Luckily for me, my tacoma was equipped with the cab wiring for the elocker. Everything was there, expect at connection "BN7" the locker wiring was not pinned out to the female side.
Diff Lock switch wiring was taped from the facoty
Here, connection "BN7" can be seen. I could have simply pinned out the wires to the female end of the connector, but upon a further inspection discovered that the pins are plated differently, and are different sizes.
Instead, I clipped the wires from the "BN7" connector, and ran my own harness to the locker motor.
Gray wire mod done
Permanent Diff Lock ECU Mounting
Installed and wired up.
Left myself plenty of room on the harness, as I will be doing LT in the rear soon.
More to come!
Old May 18, 2011 | 02:08 AM
92 TOY's Avatar
very nice Joe...absolutely love the 1st pic.
Old May 18, 2011 | 08:08 AM
PismoJoe's Avatar
Thanks Jerry! Hope to see you at one of the Jambos so you can be cruisin with me
Old May 18, 2011 | 06:03 PM
PismoJoe's Avatar
Got a little video of the successful locker swap
http://www.youtube.com/watch?v=swAHAmjWO1w
Also installed a Crown rear brake line. With my stock axle and Deaver 8 leafs, the stock line worked perfectly. When I swapped to the E-locker housing, it was too short.
Also threw on a new IAC recently. Mine was nasty!
Compared to the new one:
mmmm no more idle issues
Old May 19, 2011 | 12:40 PM
BigBluePile's Avatar
Nice Joe. Real nice.
I wish my locker just dropped in. It sounds like it locks/unlocks pretty quick!!!
Old May 29, 2011 | 01:50 PM
PismoJoe's Avatar
Thanks Logan! Yeah she does the deed, you're gonna like yours
Old May 29, 2011 | 07:02 PM
vital22re's Avatar
totally a bro
Hey joe, I just need to wire up my locker now.
Old May 29, 2011 | 08:01 PM
MaK92-4RnR's Avatar
Can't wait to see this thing in action again at Pismo this year! bad ass rig, Joe!
Old May 29, 2011 | 08:36 PM
ToyoTech559's Avatar
nice jump. love that pix. hope to see you out there at pismo doing some jumps
Old Dec 5, 2011 | 11:55 PM
PismoJoe's Avatar
Thanks man!
Got some updates...fixed my sinking cab issue!
Before:
Spot welds came off center from the factory on the passenger side, most even failing to penetrate through the metal. SMH Toyota
The Inside
Pretty descent cracks going on
Fix Time
I was able to prop the factory bottle jack in a position to jack the cab back up to its stock position
Now time for some paint!
Old Dec 6, 2011 | 02:48 AM
92 TOY's Avatar
sumbodie stole yer windos
Old Dec 6, 2011 | 08:23 AM
PismoJoe's Avatar
took er jerb!!
Old Dec 9, 2011 | 05:16 PM
Old Dec 9, 2011 | 06:02 PM
dropzone's Avatar
Fossilized
must be nice having access to two lifts
cracks in the body..sucks but no surprise with the launches that truck has taken.
kind of makes me want another Taco ex-cab..
Old Dec 9, 2011 | 08:32 PM
PismoJoe's Avatar
Thanks Logan
Yeah its really nice having access to a shop! It's even nicer that it's an independent Toyota/Lexus/Scion specialty shop, so I am very lucky indeed!
Old Dec 11, 2011 | 04:47 AM
space-junk's Avatar
no bed supports? what in the hell?
Old Jan 2, 2012 | 05:03 PM
PismoJoe's Avatar
Got the rear dyno-matted!! Its a flashing material for roofing, but very similar to dyno matt. 2 layers all around the rear of the cab.
Also took this opportunity to remount the capacitor and clean up the stereo wiring.
All bolted down nice and snug now! Originially was held in by 2 self-tapping screws. Now is mounted with 4 bolts and washers from underneath, sealed with silicone. Fuse box is bolted down and sealed too!
Old Jan 2, 2012 | 05:09 PM
PismoJoe's Avatar
GD it Troy, here's teh bed supports.
Here's a few shots of the truck after the paint job. I also picked up some new tires! General Grabber Red Letters, 33x12.5
Painted the wheel wells and sub cowl black, way cleaner look!
Had the door jams painted, under the hood as well. Fiberglass components were sealed from the underside.
Old Jan 2, 2012 | 07:30 PM
wow truck looks good. must be nice to live next to pismo
Old Jan 3, 2012 | 02:45 AM
92 TOY's Avatar
needs dirt, dents and scratches.
looks magically delicious.
