Dirtco's 1999 4Runner Build-Up Thread
Old Nov 6, 2011 | 02:33 PM
  #381
grant526's Avatar
On the note of airing up and down, I've pulled the valves out of the stems to air down and when using a compressor with a large enough tank, I've also pulled them to fill directly from the quick-connect instead of using the tire chuck (like when setting the bead). . . As far as airing up after the trail, I have a 4 way hose that I built to inflate all 4 tires at once and to the exact same pressure. It also has a radiator valve on it that works great for deflating all 4 at the same time & to the exact same pressure...
Old Nov 6, 2011 | 02:37 PM
  #382
grant526's Avatar
An old buddy of mine has been wheeling a Scout II for longer than I've known him or can remember. He specifically installed a second valve stem on his wheels (opposite the original, like yours) so that he can check his tire pressure when airing up without removing the fill hose and slowing the process if it's not quite full yet.
Old Nov 7, 2011 | 03:11 PM
  #383
adrenalinepirate's Avatar
What arb compressor is that?
Old Nov 7, 2011 | 04:43 PM
  #384
DIRTCO's Avatar
That's how I used to air down. I would just pull the valve core, it was fast but a little cumbersome when it's below zero and your fingers are numb. I also had a tool (a PSIclops) that would fill two tires at a time, but one of the chucks got wore out and were not replaceable. I like your buddy’s idea of adding a second valve stem, that would work really good if you have steel wheels.
Old Nov 7, 2011 | 04:44 PM
  #385
DIRTCO's Avatar
It's the standard one, not the mini.
Old Nov 7, 2011 | 07:41 PM
  #386
gryllswannabe's Avatar
i had to put all my projects on hold when i got orders to Japan...but when i get an assignment back to the states, i am hoping for CO...AFA instructor...hopefully i can see this beast in person one day...
Old Nov 14, 2011 | 06:08 AM
  #387
cRoW's Avatar
dirco.... great build i love everything about ur runner.
Old Nov 17, 2011 | 04:30 PM
  #388
DIRTCO's Avatar
Thanks man!
Old Nov 17, 2011 | 04:31 PM
  #389
DIRTCO's Avatar
I pushed the 4Runner into the shop this last weekend, I wanted to work on the sliders but it’s a little hard when I can’t move the vehicle. So I worked on the rear cargo area so I can get all my wheeling gear in place. I didn’t finish the project but I did make some progress.
The plan is to install a 1st Gen 4Runner roll bar; it will be a good base to mount all my stuff and since I’ve always been a 1st Gen guy, it adds a touch of nostalgia to the new 4Runner.
The front legs have to be cut down to fit the 3rd Gen 4Runner, most people re-use the stock plates but I had a set of Ballistic plates that have four mounting holes and are more heavy duty.
Sorry for the crappy pictures, I forgot my camera and had to use my phone.
Before I could bolt the roll bar in place I needed to figure out a better storage solution. I carry a lot of gear with me, and since I do a ton of wheeling without much notice it needs to be in the truck at all times. Here’s a picture of the Turbo 4Runner and all my gear, the cargo area of the 3rd Gen is even smaller.
I decided to build a removable rack that will bolt to the roll bar and hold two Action Packers above the subwoofer box along with my Hi-Lift, it will have expanded steel on the bottom.
And some better pictures
Old Nov 17, 2011 | 04:36 PM
  #390
ToyoTech559's Avatar
nice. i been thinking of a similar idea but i never know when and if i need to fold the seats for whatever reason. i too have been playing with the idea of it being removable but i have installed the 3 point seat belt in the place were i want the cargo area to bolted to
Old Nov 17, 2011 | 04:40 PM
  #391
JBurt's Avatar
Good idea. Curious to see how it attaches. Any word on when the SC is supposed to be back?
Old Nov 17, 2011 | 04:58 PM
  #392
2DoorJoRunner's Avatar
Oh man, I love that idea! The removable rack plus the roll bar is great!
Old Nov 17, 2011 | 05:16 PM
  #393
DIRTCO's Avatar
There will be tabs off the roll bar and the cargo box. I really doubt that I'll ever remove it, but I want the option if I need to. Longer stuff can slide under the rack with the seat folded down, and even in an emergancy I should be able to sleep under the rack.
I hope the supercharger will be back the day before or after Thanksgiving, otherwise it will be the following week. I hope it's soon!
Old Nov 17, 2011 | 06:04 PM
  #394
dropzone's Avatar
Fossilized
You always come up with cool and innovative solutions
I think i am gonna borrow this idea for my Trekker
Old Nov 17, 2011 | 06:54 PM
  #395
TinMan's Avatar
Hey man were did you get the weld on tabs you are using for ratchet strap tie downs. Thanks
Old Nov 21, 2011 | 04:57 PM
  #396
DIRTCO's Avatar
Thanks man! I think it should work really good for what I want and need. Let me know how it works in your trekker
They are just some random tabs I had around, you could use just about anything.
  #397
DIRTCO's Avatar
More progress
Bolted in place
Action Packer in place
CO2 Tank
Old Nov 21, 2011 | 07:37 PM
  #398
It almost looks stock. Smooth.
Old Nov 21, 2011 | 08:26 PM
  #399
looks good. i need to play with some ideas. looking at a light weight aluminum basket already made
Old Nov 21, 2011 | 11:20 PM
  #400
JBurt's Avatar
Sweet idea! Well executed as always. Why did you choose the cargo area for the co2? It seems to take up a lot of space. Are you using the stock spare location for anything? It would take some plumbing to make it useful but I'm sure you've already thought of that and have a good reason for putting it where you did. I guess I'm just curious as what that reason would be.
