Addicted Offroad's 2000 4Runner Build-Up Thread "Intervention"
Old Apr 10, 2010 | 03:49 AM
  #201
wyorunner's Avatar
WOW!!! This rig is going to be awesome. I think you have more in parts than most do in there total vehicle. And that is a lot of money. Are those the 35s on the back currently? I need a new lift due to EXTREMELY heavy bumpers. And if I could squeeze 35s on that would be fantastic. I know id have to do some pinch weld trimming up front if i stay IFS but thats ok. Sorry for the short hi-jack. Keep up the spending and bringin on the toyota pron.
-Wyo
Old Apr 10, 2010 | 04:54 AM
  #202
ScottyC's Avatar
-Wyo
Those are the 37" MTRs. I would think that a body lift would be in order to fit 35s with only a 3" lift.
I told myself that if I was going to build this the way I wanted, then I was going to do it right the first time. I have built so many rigs, that I just know what I want and what I don't.
That and when I sold the silver one to John, I had a pretty good chunk to throw at parts for the new one.
Old Apr 10, 2010 | 05:02 AM
  #203
wyorunner's Avatar
Thats impressive id didnt think the 37s would fit that easily on the rear. How did you decide what coils to go with? The spec part weight and length?
Old Apr 10, 2010 | 05:05 AM
  #204
ScottyC's Avatar
Originally Posted by mikec
Looking to buy 89-95 extended cab 4x4 w/o drivetrain and in good condition. Will travel if fairly priced. valleystaky@yahoo.com
Uh, okay....................
Old Apr 10, 2010 | 05:08 AM
  #205
ScottyC's Avatar
I did a lot of research on what spring rate I wanted and what lift I wanted to get out of it. They are OME 851s.
They are front coil springs that are light duty for FJ80 Land Cruisers. They yield are 1.5"-2" of lift on an 80. They are 10in/lbs heavier than the OME coils I ran in my silver 4runner. So, I figured that it should ride very similar, and given how much longer the coils are over stock, they should flex GREAT!
The 37s are going to require trimming. I will be moving the rear axle back at least 3" to allow the tires to clear the wheel wells. The back of the wheel well will need to be trimmed out and boxed back in.
The same goes up front. It will be moving forward a couple inches over stock. The wheelbase should end up around 108-109"
Old Apr 10, 2010 | 05:19 AM
  #206
wyorunner's Avatar
I understand the rear, but I meant to say (but didnt) the coilovers for the front.
Old Apr 10, 2010 | 05:29 AM
  #207
ScottyC's Avatar
pm'd you back
Old Apr 10, 2010 | 05:47 AM
  #208
wyorunner's Avatar
Thanks for the info. Good luck and cant wait to see the end result!!
Old Apr 10, 2010 | 07:47 AM
  #209
paynemw's Avatar
i cherish this thread, if i had the money and the time off from work, i drive out to your shop to be the bum that sits outside yer shop and druels over the work you do as i cry and whine that my truck isn't nearly as badass, continue to thrill us all scotty
Old Apr 12, 2010 | 02:32 PM
  #210
ScottyC's Avatar
IFS is now completely gone.
Old Apr 12, 2010 | 04:47 PM
  #211
dannomite's Avatar
That is beautiful
Old Apr 12, 2010 | 06:16 PM
  #212
StangBanger's Avatar
LOL..are those black jackstands the dedicated SAS jackstands?
and I would be the second bum that comes around offering to sweep the floors just to be closer to the action..lol
Old Apr 12, 2010 | 06:30 PM
  #213
ScottyC's Avatar
Pretty much. I have 4 of them though that we built.
Old Apr 13, 2010 | 11:46 AM
  #214
cool..
Old Apr 13, 2010 | 12:15 PM
  #215
Kuntryboy's Avatar
hurry up and finish!!! hahaha jk but seriously hahaha
Old Apr 13, 2010 | 02:25 PM
  #216
ScottyC's Avatar
Frame plating in progress.
Boxed in the motor mount
Old Apr 16, 2010 | 12:24 AM
  #217
vwfastg60's Avatar
Saw this last weekend and it makes me tingle in special places lol
Old Apr 16, 2010 | 01:31 AM
  #218
Dgfriend707's Avatar
Awesome build...
Subscribed
Old Apr 16, 2010 | 05:29 AM
  #219
ScottyC's Avatar
I'll have some updates today. Hoping to have the duals installed so I can start messing with the frame crossmember for the front links.
Old Apr 16, 2010 | 10:31 AM
  #220
ScottyC's Avatar
Well, I have been getting my ass kicked by the Prerunner adapter. Turns out that Inchworm has two different versions of couplers. One has a middle neck in the coupler. The other is just splines all the way through it. I got the one with the middle neck.
Because of that neck, the crawl box will not sit flush against adapter without pushing the crawl box input back against the reduction box housing and keeping it from turning. Its like its off by 3/16" to 1/4".
So, Jonathan is sending me out a new coupler.
Other than that, I am going to go ahead and install everything else so I can at least get some measurements on stuff and to start to build the front link crossmember.
