Where to tap for gauges?
Im doing a gauge install in My 4Runner and my uncle's 98 Tacoma
In mine Im gonna do Defi BF Gauges, EGT, Oil Pressure, and Fuel Pressure. Where should I tap for the gauges? Which exhaust runner should I put the EGT gauge in? WHere should I tap fot the Oil and Fuel Pressure?
In my uncle's Im doing Autometer gauges, EGT, Oil Pres, Fuel Pres. Where should I tap for the gauges? Which exhaust runner should I put the EGT gauge in? WHere should I tap fot the Oil and Fuel Pressure?
Should they be the same? Theyre both 3.4L (5VZ-FE?).
He has Downey headers going in, I have TRD Headers going in, if tha tmakes a difference
bob_98sr5 has a writeup for an oil pressure gauge install.
http://www.4runners.org/articles/gaugeoil/
I know it doesn't necessarly pertain to the 3.4L, but on my Celica, it is recommended to tap between #2 & #3 runners because they run the hottest...
Originally Posted by Gangus2006
thanks...now i just need to know on where to tap for fuel pressure and which runner for the EGT
Read the instruction sheets, my man! It's all there and its very clearly articulated. If you dont have them, you can download the pdf instruction sheets from the Autometer website. Also, if you dont know which wires to tap, try www.the12volt.com 's wiring reference database/engine
also, check out gadget's gauge webpage
bob
Quick question. What is the maximum fuel pressure in the 3.4L? Should I get the 15PSI Gauge or the 100PSI gauge?
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
