Where to tap for gauges?
Old Nov 29, 2004 | 04:55 PM
Gangus2006's Avatar
Im doing a gauge install in My 4Runner and my uncle's 98 Tacoma
In mine Im gonna do Defi BF Gauges, EGT, Oil Pressure, and Fuel Pressure. Where should I tap for the gauges? Which exhaust runner should I put the EGT gauge in? WHere should I tap fot the Oil and Fuel Pressure?
In my uncle's Im doing Autometer gauges, EGT, Oil Pres, Fuel Pres. Where should I tap for the gauges? Which exhaust runner should I put the EGT gauge in? WHere should I tap fot the Oil and Fuel Pressure?
Should they be the same? Theyre both 3.4L (5VZ-FE?).
He has Downey headers going in, I have TRD Headers going in, if tha tmakes a difference
Old Nov 30, 2004 | 11:10 AM
Gangus2006's Avatar
BuMp!
Old Nov 30, 2004 | 11:15 AM
SLC Punk's Avatar
bob_98sr5 has a writeup for an oil pressure gauge install.
http://www.4runners.org/articles/gaugeoil/
Old Nov 30, 2004 | 11:41 AM
Gangus2006's Avatar
thanks...now i just need to know on where to tap for fuel pressure and which runner for the EGT
Old Nov 30, 2004 | 12:05 PM
SLC Punk's Avatar
I know it doesn't necessarly pertain to the 3.4L, but on my Celica, it is recommended to tap between #2 & #3 runners because they run the hottest...
Old Nov 30, 2004 | 12:23 PM
Gangus2006's Avatar
hmm...I thought the #5&6 cylinder ran the hottest since they come earlier in the fuel rail...
Old Nov 30, 2004 | 01:35 PM
Bob_98SR5's Avatar
Gangus,
Read the instruction sheets, my man! It's all there and its very clearly articulated. If you dont have them, you can download the pdf instruction sheets from the Autometer website. Also, if you dont know which wires to tap, try www.the12volt.com 's wiring reference database/engine
also, check out gadget's gauge webpage
bob
Old Dec 1, 2004 | 10:04 AM
Gangus2006's Avatar
Quick question. What is the maximum fuel pressure in the 3.4L? Should I get the 15PSI Gauge or the 100PSI gauge?
Old Dec 1, 2004 | 12:35 PM
Gangus2006's Avatar
BuMp!
Old Dec 1, 2004 | 01:09 PM
Gangus2006's Avatar
never mind, found the answer...
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 02:11 PM
beltcutter
Sep 30, 2015 06:14 AM
