wheel spacers w/ trd fj rims?
Old Jan 19, 2009 | 06:23 PM
M threezy's Avatar
I'm running the trd fj rims with 285/75/16. At full lock the tires rub the upper control arm. Is anyone running wheel spacers with these wheels?? If so, what size spacer?? Please post pics if you guys have them.
Old Jan 19, 2009 | 06:38 PM
sa51's Avatar
this is what i was worried about running newer yota rims with larger tires on old rigs, there is so much backspacing that it puts the tire inward, rubbing on things like the control arm. i think a 1 inch spacer would solve the problem though.
Old Jan 19, 2009 | 06:42 PM
M threezy's Avatar
ya, i'm thinking about going 1", but just want to see what others have used. i dont want the wheels sticking way out.
Old Jan 19, 2009 | 06:48 PM
sa51's Avatar
i'd have to agree, i think any wider then 1 inch isn't good either. i'd like to see some replies. only a few people have been running the 05 and up taco and fj rims but i'm sure the trend will increase.
my 10.5 wide 33s rub my idler arm at full turn, i have 15x7 stock 99 taco rims.
idk why i didnt ask, what vehicle are your rims on?
Old Jan 19, 2009 | 06:54 PM
M threezy's Avatar
they're on a 00 4runner.
Old Jan 19, 2009 | 07:03 PM
sa51's Avatar
well hopefully someone else has some first hand experience, but i think 1 inch spacers should do the trick. i'd also like to see how the rims look on your truck
Old Jan 23, 2009 | 09:14 PM
M threezy's Avatar
anybody???
Old Jan 23, 2009 | 11:09 PM
TOPSECRETTUNDRA's Avatar
Can I see what they look like on your 4Runner?
Old Jan 24, 2009 | 03:55 PM
M threezy's Avatar
sure, i will try to get pics tomorrow. the weather kinda sucks at this moment.
Old Jan 24, 2009 | 06:36 PM
trd_4runnin11's Avatar
I won't have my 285's for a couple weeks but I have the 05+ taco wheels with spidertrax 1.25" wheel spacers. Here are a few pictures I have of my 4runner with this set up. If you want any other angles just let me know and I'll snap some more pictures tomorrow.
BTW these are the stock 265/70s
Old May 13, 2009 | 11:27 AM
Jason B's Avatar
Update. For anyone wanting Spidertrax spacers, they will be shipping may 18-19th. These have been out of stock for over the past month. Spidertrax cannot make enough, and when they do make a run, they are all sold out before they can put them up on their own site!
We bought 30 sets just for us, which will ship may 18-19th. I ONLY HAVE 10 SETS LEFT, so if anyone else wants a set, I'd order in the next 1-2 days so you get a set. If you wait, it's going to be another 1-2 months until they can make more.
http://www.burtmanindustries.com/zoo...r_spider_96_02
Old Aug 6, 2009 | 06:49 PM
alteredvision's Avatar
I know this is an old post but I am doing the same thing and want to know how it turned out. I have 285/75- 17's steel rims of an FJ Cruiser and am thinking that if I got the spider Traxx 1.25 then I would stop rubbing the UCA's. Did this work for you?
Old Aug 6, 2009 | 07:01 PM
24x4runnersport's Avatar
lift it or run 265 70 17, very simple
Old Dec 27, 2009 | 06:24 PM
protosite's Avatar
spacers
This may not be applicable to your year, make, and model but chances are it does. I ordered and installed a 3" lift and 1.5" wheel spacers so my 08 fj could take 285/70/17 tires on stock 07 Tacoma TRD Sport wheels. The result was perfect for backspacing clearance, but the lift is still a bit shy of keeping the tire from rubbing a protruding piece of inner fender, especially when turning in reverse. I'll likely go up an additional 3" later but the 1.5" wheel spacers were perfect for the purpose of getting good clearance from the upper A-arm. The tires don't stick way out past the fenders either. Hope this helps.
Attached Thumbnails wheel spacers w/ trd fj rims?-fj-spacers-lift.jpg
Old Dec 27, 2009 | 06:41 PM
michalik_piotr's Avatar
Do what you gotta do but price all thats included in replacing a wheel bearing (plus labor if not doing it yourself) first then think twice. I'd rather run a diff rim and/or tire then spacers. I would not even want to shorten the life span of my bearings by a 1,000 miles just having to replace one.
Old Dec 27, 2009 | 10:45 PM
protosite's Avatar
I understand your train of thought and agree to a point. First, to get what you want, we are all willing to make different levels of sacrifices. Secondly, you must consider the geometry as it was before versus as it will be after for each SPECIFIC application. In my case the hub is now actually close to 0 offset which will not cause any great stress on the bearings. Once one begins running in the negative offset, then they should consider setting funds aside for premature failures.
Old Jan 20, 2010 | 12:42 PM
haddix's Avatar
Bumping this thread..What size wheel spacers do I need for these rims and 315/75/16? Ive got 1.25'' now..Think that will be good enough or go with 1.5''?
Old Jan 20, 2010 | 04:52 PM
4runner114's Avatar
iv got fjs on 285/75/17 with 1" wheel spacers and everythings good
Old Jan 21, 2010 | 07:28 AM
protosite's Avatar
Yes Haddix, I agree with 4Runner114. You should be fine with your 1.25" spacers and 315's....assuming you're talking about the later model front IFS and your rims have a stock positive offset (+10mm if I remember right). If they are not stock, then you'll have to break out the tape measure and figure it out. With my 1.5" spacers and 285's, my hand had 1.5 to 2 inches of room to flop back and forth between the tire and the upper A-arm. Also to tweak my previous comment...When I said negative offset being an issue for the bearings, I meant HUGE negative offset. Up to -15mm is not unusual and not an amount to consider detrimental to your bearings. I have, since my last post, removed my Tacoma TRD Sport rims and 1.5" spacers from my FJ and replaced them with MOTO Metal MO951's that have a -12mm offset. This is very close to what the stock rim and spacer combo produced. The 285's stick out just ever-so-slightly past the flares and give a broader, muscled stance but still somewhat understated look.
Attached Thumbnails wheel spacers w/ trd fj rims?-p1050242.jpg
suppra87
Jul 15, 2021 05:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Cycles
Sep 29, 2015 06:37 AM
4runnerFireman
Sep 29, 2015 06:24 AM
83
Sep 27, 2015 04:13 PM
