wheel bearing woes, please help
Old Apr 10, 2006 | 07:07 AM
jdery's Avatar
I need to change the wjeel bearing on my 01 Taco4x, but I'm haveing some probs getting the grease cap off. any suggestions? I would rather do it myself than spend the 500.
Old Apr 10, 2006 | 08:20 AM
BajaRunner's Avatar
You're not talking about the black dust sheild are you?
Old Apr 10, 2006 | 08:30 AM
jdery's Avatar
Yes, thats the one. Should I just pry it off
Old Apr 10, 2006 | 08:32 AM
jdery's Avatar
Its that black cap that fits tight around the end of the hub
Old Apr 10, 2006 | 09:24 AM
Crux's Avatar
Get a large flat chisel and lightly tap all the way around it with a rubber mallet.
It takes awhile, but it should start to move and pop off.
I also had to spray a lot of PB blaster on it
Old Apr 10, 2006 | 09:32 AM
GSGALLANT's Avatar
X2. I did the same... with a large flat screwdriver. Don't use anything small or pointy. That dust shield is pretty thin, and you can go right through it. I also sprayed it with a penetrant before starting.
Old Apr 10, 2006 | 09:37 AM
SpikeStrip's Avatar
You can also go to Autozone and buy a Grease cap removal tool, for 8 bux; it's basically a big pliers with jaws that'll grip the dust cap, but the methods mentioned above will work just as well. If you bang up the dust caps badly, you can always replace 'em cheaply.
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
PlayAwhile
Jul 20, 2015 11:36 AM
