What year is this truck?
Old May 23, 2005 | 11:43 AM
stevrock's Avatar
nope, 88 is when they came over tothe early 90's style.
The bed rail was outside up until then.
Old May 23, 2005 | 11:44 AM
Toys-R-Us's Avatar
Man, you guys have good eyes. I can't pick up anything from that....
Old May 23, 2005 | 11:56 AM
Glenn's Avatar
however it is from a 4x2, as no 4x4 had externall bedrails after the 83 model year...
Wrong. I have seen many external bedrails on '84 and newer 4x4's. External bedrails means the bed was made in Japan, and the internal bedrails mean the bed was made in the US and installed on the truck after it was imported.
Old May 23, 2005 | 12:23 PM
aviator's Avatar
looks right to me
Dude that truck looks like a perfect example of the early '84 hilux (truck). Looks very clean and well cared for too. they did have exposed bed rails all the way up to the change over to the 3 gen. (89-95) they had hooks on the '84s. that style of two-tone was factory spec. and the rims are correct for '84 and '85.
Places to check for rust are the seams of the box. that is lower rocker panel/box side & box side/top rail curve & tail gate. other wise they were a good solid truck. If it was regularly oil sprayed there should be no real rust issue though.
As previous posters have said check the drain lines from the sunroof for clogs (it is a peice of hose that runs from the sun roof down to the lower rocker panel [on some 4runners it ran down the a pillar and on some trucks it went down the b pillar i think]) in either case it connected to a body drain hole.
hope this helps Aviator
duckhead
170
Nov 13, 2017 06:07 AM
bigblue82
10
Jul 6, 2015 08:27 AM
saphirekosmos
Jun 22, 2015 10:26 AM
Grimace
Jun 11, 2002 05:56 PM
