What is this switch in my fuse box?
Old Aug 18, 2010 | 02:58 PM
JBurt's Avatar
It doesn't have a battery backup (I think). The alarm only goes off when I put the battery cables back on. I pulled the two fuses (15A and 5A) going into the alarm box but neither kept the alarm from going off. Lame. Also the fcc id is ELVAR5C which apparently is the least common fccid ever. No remotes on ebay or google. Lame again.
Old Aug 18, 2010 | 03:35 PM
Zim's Avatar
Zim
Can you get some pics up of how they tied into your electrical system?? These alone with the wires that they tapped into could help us lead you in the right direction. Pull off the left kick panel all the way. Also the lower dash trim as alarm co. love to hide other interesting things that may be hard wired past the fuse to stop theft. Should be only 3-4 main wires for the system. One, 12volt constant, one 12volt ignition or memory, one or two grounds. Follow that wire for the valet switch as that should lead you to the 12volt system. Hope this helps.
Old Aug 18, 2010 | 04:35 PM
JBurt's Avatar
So I just unplugged the brain and the truck works (not that that's a permanent solution). I think I'll just rip it out. The only benefit I can see to a 12 year old alarm is if it has a remote starter but I don't see an antennae for one. What should I look for to determine if this system was equipped with one? Thanks for all your help guys. I appreciate it a lot.
80Truck
Oct 12, 2025 07:25 PM
Mrhoadley
Aug 4, 2015 06:08 PM
Esibnitsud
Jul 30, 2015 08:19 PM
rushw
Jul 18, 2015 01:46 PM
crashburnoveride
Jul 10, 2015 06:39 AM
