What is this?
I don't see anything connecting it internally to the transfer case but I can't really find anything in the wiring diagrams either and I don't know what category to look at in parts diagrams to find out what it is..
could be some sort of vacume mechanism to shift maybe??? it's got a hose. does it lead to the transfer case?
It routes around to the top side of the transfer case just above on the topside of the case just above of where that plug wraps together that has the green wrap on the wiring
Looks like a transfer case shifting mechanism for the trucks that have push button 4wd. Do you have a 4wd shift lever or do you have a switch that you push or turn to activate 4wd.
there is a button to activate 4WD but there is a shifter to select H4 and L4.. I don't see it going into the transfer case at all so that's where i'm confused about what it may be..
Now I am not swearing that I am correct. I am very unfamiliar with anything past 95. However I have owned several fords that are setup with the electronic transfer case shifter. And yours looks exactly the same.
