weird texture on dipstick
Old Jul 10, 2003 | 08:40 AM
Amir904's Avatar
i was checking my oil yesterday and there is some weird substance on my dip stick when i check the oil, its rust colored and slimy. oil is fine, not dark at all, i have 76k miles. but i dono what this stuff is, anyone have any idea? i am due for an oil change, 3200 miles, but i shouldnt be seeing this stuff, should i?
Old Jul 10, 2003 | 08:42 AM
rimpainter.com's Avatar
A picture speaks a thousand words.
Old Jul 10, 2003 | 09:04 AM
BT17R's Avatar
Too many variables to say right now, so fallback to "it depends".
How long (timewise) since your last change? What is your typical trip length? If less than 10 miles in chilly Pittsfield, it may just be normal grunge found during Winter operation. What brand and weight oil do you use? OEM Toyota oil and air filters? Changed with the oil every time? What does the coolant look like? Have you owned the rig since new? Can you easily pull a valve cover to look for sludge buildup? When was the PCV valve replaced? Is the EGR working properly? Anything besides steam coming out the tailpipe at cold start and after warmup?
We'll narrow it down, and it'll probably wind up being normal, but those are a few things to consider for now.
pickle6415
Apr 14, 2021 06:20 AM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JamesDINAN
Sep 22, 2015 05:37 AM
viesail
Sep 5, 2015 04:23 AM
