VSC/TRAC/ABS Disable mod for Tacoma
Old Oct 31, 2008 | 09:57 PM
Spoon1179's Avatar
Been looking all over the web for a good write up on how to disable VSC/TRAC/ABS for the 04 Tacoma with a flip of a switch. It would be awesome for when I'm wheeling and want to have some fun. Probably help too when going down hill or in soft sand. I checked out the Andy mod ( https://www.yotatech.com/forums/f2/v...3/index15.html ) to turn off the the TRAC but that was for a 4runner. Not sure they are the same thing. In some of my research I even read that some of the 04 tacomas don't even come with VSC. Has anyone done a mod like this? Or know how to do it? Pictures would be a plus.
Thanks for the help.
Old Nov 1, 2008 | 08:36 AM
EnolaGaia's Avatar
2004 was the only (pre-2005) model year in which the VSC / TRAC system was offered on Tacomas.
It was an option, and relatively few 2004 Tacos have it.
Check the email account you listed when you registered over at CustomTacos (where I'm a moderator). I've sent you the wiring diagram.
Old Nov 1, 2008 | 11:43 AM
Spoon1179's Avatar
Thanks for the diagram. But to be honest... I'm not too good at reading it. Is there somewhere to look in the truck to see if i have it. But I'm guessing that my truck don't have VSC or TRAC from what you said. So if that is the case, does anyone how to disable the ABS with the flip of a switch? Has there been a write up on that yet for the 04 Taco or similar?
justdifferentials
14
Jun 11, 2017 08:36 PM
punks_is_4x4
May 31, 2016 06:03 AM
G-off
Dec 29, 2015 12:44 PM
langry345
Sep 14, 2015 03:36 PM
Boomer8404
Sep 10, 2015 09:01 AM
