Very Confused... 1/2" lift from OME881?
Old Sep 25, 2007 | 05:48 PM
SnoViking's Avatar
howdy all.... so Im very confused. i picked up a set of OME881s on beilsten struts. I put the one assembly on the truck and Im only getting 1/2" of lift.
Now my truck has always sat high in the front. Its a '99, but Im confused. On the stock side, from center of the hub to the bottom of the fender flair (SR5) it is 21.5 inches. On the new OME881 side, it is 22 inches.
So im wondering if my "stock" set up is actully that. My stock set up is a tokico strut with a coil that has a blue and a pink/red swatch. My rig is a '99 SR5 with 160k miles. I would think if it is stock it would have sagged some in the past 160k miles.
Do the OME's have sides like the factory springs do? drivers side and passenger? I do not see any color swatches on them?
any help out there?
Old Sep 25, 2007 | 05:55 PM
SnoViking's Avatar
also, can anyone out there with a stock '99 SR5 give me some measurements of hub to bottom of fender flair?
Old Sep 25, 2007 | 06:37 PM
SnoViking's Avatar
anyone with any ideas?
Old Sep 25, 2007 | 06:52 PM
MillerPKA's Avatar
not to be an a hole but my setup is still for sale, that's a guranteed 2.5" lift...
Old Sep 25, 2007 | 06:57 PM
SnoViking's Avatar
lol.. no offense taken... ill let you know when i find out some other stock specs
Old Sep 25, 2007 | 07:11 PM
Nate08's Avatar
If I'm not mistaken the 881's provide 1.25"-1.5" over stock and from what I can tell the lift measurements are from the 96-98 4Runners. The 99's and early 00's sit one inch higher than any other year 4Runner, so 1.5" on a 98 with 881's would only be .5" on a 99.
Old Sep 25, 2007 | 07:27 PM
chad99's Avatar
Hey RooRRunner how much do you want for the lift and is it the OMEs and LCs and shocks or just the coils?
Old Sep 25, 2007 | 09:55 PM
MillerPKA's Avatar
full front suspension setup including ome 882s, oem topouts, ome n91s and extended studs for adding in a top spacer if you'd like. 375 obo + shipping
Old Sep 26, 2007 | 05:29 AM
BajaRunner's Avatar
See, I only got about 1" tops from the OME 881's when I used them. The rear on the other hand was lifted 3"+
Old Sep 26, 2007 | 07:23 AM
heddleston's Avatar
I got the same results, about .5 inch of lift in the front. For the 99's, I think the 881's give you about .5 inches of lift. I was very surprised too. My 891's in the rear lifted it about 1", maybe a little more.
Old Sep 26, 2007 | 09:33 AM
landozion's Avatar
I just purchased a 99 SR5, (no pics yet) and per your request for measurements, I get 21.5" from center of hub to fender lip at the front and 21" passenger side and 22" drivers side rear. Looking underneath I think its still stock suspension (107K miles) and looking at the measurements I need new springs.
Old Sep 26, 2007 | 10:05 AM
Jdizzydub's Avatar
Just wanted to second the thought..kinda hesitant of putting the 881's on my 97' that are sitting in my living room. Just waiting for a new top plate for instal to remove my daystar coil spacer. What I've found is that it would give you 2.5 of lift but on Toytec's site they state a full 3. We'll see when they go on but moving forward the info above sounds right--the 99 does sit higher.
Old Sep 26, 2007 | 10:15 AM
skjos's Avatar
I just did the 881 lift on my 2002 4runner (the so called low-rider of the 3rd gen's). It provided 2.5" of lift exactly.
If your stock '99 is 2" higher than the stock '02, you will only get 0.5".
Old Sep 27, 2007 | 03:57 PM
CASTAIC 4RUNNER's Avatar
hey dudes i was going to buy OME 881 and a 1 inch daystar coil spacer for the front and OME 906 for the rear ... what do you think this will do for me??
Old Sep 27, 2007 | 04:08 PM
Nate08's Avatar
I think your front would be higher than the rear. IMO go with the OME 890's. They'll give aboue 2.25" to 2.5" of lift and should be almost even with the front.
Old Sep 27, 2007 | 04:09 PM
Nate08's Avatar
I think your front would be higher than the rear. IMO go with the OME 890's. They'll give about 2.25" to 2.5" of lift and should be almost even with the front.
Old Sep 27, 2007 | 04:49 PM
cubcilecaptive's Avatar
Sounds like you have a Sonoran suspension on that rig already. Tokico shocks are not standard and that set-up is old school Sonoaran. He uses factory Toyota shocks/struts these days.
Old Sep 27, 2007 | 06:25 PM
SnoViking's Avatar
I think im going to sell the blientein and OME881 setup and just do a simple 1 inch spacer lift... anyone want to buy the OME881 setup?
Old Sep 27, 2007 | 07:00 PM
MillerPKA's Avatar
no you want my lift kit!!!!!! spacers are the devil!
Old Sep 28, 2007 | 04:35 PM
MTL_4runner's Avatar
Why on earth would you sell those and go back to spacers?
You only got 1/2" because you didn't use a topout spacer up front.
Typical gains vs year
96-98 => 1.5"
99 => 0.5"
00 => 1.5"
01-02 => 2.5"
