Very Confused... 1/2" lift from OME881?
Old Sep 28, 2007 | 04:58 PM
CASTAIC 4RUNNER's Avatar
what do you guys think about the 906 rear coils? 4wheelparts told me 2 inch lift ... but that has to do with 96-02 so that means i will get a 1 inch lift?
Old Sep 28, 2007 | 05:03 PM
1999runner's Avatar
do an 890 i just returned the 906 it was way lower than my front on my 99, even with the 890 my front is 3/4 lower with only a daystar 1" spacer and no top out spacer, with the top out spacer everything was maxed out and was a good 1/2 higher than the rear with 890. the 99 are to tall to work with a spacer lift, trust me this my second 99.
Old Sep 28, 2007 | 05:18 PM
what do you mean it was lower than you fronts on your 99? like factory fronts or modified fronts? did it give you a lift at all or lower it ?
Old Sep 28, 2007 | 05:27 PM
MTL_4runner's Avatar
He's got a spacer up front, that's why the 906's were too low in the rear.
Old Sep 28, 2007 | 05:28 PM
  #25
1999runner's Avatar
ok i just reread my post not very clear
so...
daystar 2.5 front 906 rear front was a good 2" taller that the rear, 906 gave me maybe a 1/2 " lift
daystar 2.5 front and 890 rear with the cone, front was still a 1/2 in taller than the rear
final fix and love it
2.5 daystar lift NO TOPOUT SPACER only the spring spacer and 890 rear with cones, front is now about 3/4 " lower than the rear.
fits 285s easy with a little trimming rides great love it
hope that helps the daystar kit with the top out spacer caused some vibration in my front end also, it was just to high and the cv were hating it even with the diff drop.
Old Sep 28, 2007 | 05:32 PM
  #26
thanks alot for the info it really helped me
Old Sep 28, 2007 | 05:50 PM
  #27
1999runner's Avatar
glad to help the 99s are crazy beasts!
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
