Valve Cover gaskets
Not sure about clearance on the supercharger, but with the regular (and likely smaller) intake mani I'd agree with Malcolm - it's vaguely feasible to get the passenger side done, not even worth trying on the driver side.
As a short term fix, you might try ***GENTLY*** tightening all the bolts you can reach. They have rubber washers under the bolt heads, which shrink and collapse over time, allowing the valve cover to get loose and start leaking. Gently tighten them (cranking them down tight is just a recipe for breaking the valve cover) might stop the leak for another 20 - 30K miles.
Many thanks for both answers. It is tight for sure on the drivers. will try gently tweekin the valve cover gasket for now. Will buy the gaskets and have ready.
BJ
BJ
Grn99Runner
Jul 14, 2011 09:21 AM
TStango
Aug 22, 2005 05:11 AM
