v6 drinks coolant
v6 drinks coolant
Hello all, I have a 98 4runner v6 and have been putting coolant in it every other time I fiil up for about 4 years. I dont put alot, just enough to top off the over flow. There are never any puddles, it just drinks it. Also I dont know if its related but a mild knocking sound coming from the water pump area is getting louder. Any ideas?
overflow tank, when engine is cold, should have maybe 2 inches of coolant in it...
never full. never half full (unless engine is hot, then maybe it is half-full)
v6 drinking coolant
Thanks you all for the replys. Here is what I can tell you. I only fill the overflow when the engine is hot so when it cools the radiator sucks it in.
No I havnt checked the ATF fluid, my tranny isnt connected with coolant is it?
My engine oil is fine, never turns any color other than dirty.
And yes, your tranny is connected to your radiator. The fluids are only separated by a very poorly designed heat exchanger that fails often. Use the search tool for "stawberry milkshake". It will frighten you.
Also, if your coolant is really disappearing without leaving any leaks or puddles, consider that it may be leaking into your combustion areas through a bad head gasket or cracked head. It would manifest itself as a sweet smell from your exhaust and a white smoke if bad enough.
Welome to YotaTech, btw.
Interesting...I have a 00 taco prerunner with 180K, since the T/B W/P was done 80K/ years ago, it has used probably a quart of coolant,it just dissapears,no leaks,no crusties..nada,just did the plugs and all were identical moreless. trans looks normal also,can help but think theres still a H/G problem on some. The 180K 98 runner dosent have this issue in the 35K we've owned it.
LittleUgly
15
Jan 2, 2020 01:30 PM
kcaudill
Oct 10, 2015 02:39 PM
