Upper Timing Idler Question 3vze
Old Apr 10, 2004 | 07:15 PM
radrex's Avatar
Is there suppose to be a gasket between the upper Timing Idler and the Intake Manifold or do you just use Sealant?
Old Apr 10, 2004 | 09:55 PM
Nor_Cal2ndgen's Avatar
Toyota recommends sealant, and as far as I know there is no such gasket available. When you buy a new idler from Toyota, the sealant is pre installed by the factory. You can use a good quality RTV, but I would suggest a product form Permatex called "The Right Stuff" for any job that requires sealant. If you have never used it, get it now and you will never go back!
GreenLion
Jun 7, 2021 10:49 AM
voiddweller
19
May 2, 2016 09:10 PM
Vargntucson
Jul 4, 2015 12:15 PM
Niameyrider
Jun 25, 2015 05:50 AM
