Undercoating for a bedliner??
Old Aug 19, 2005 | 12:26 PM
pat2724's Avatar
I just took my bedliner out on my Tacoma and I was wondering if you can use Undercoating from NAPA to use instead on Rhino(to much$$).
Has anyone used it before??
Thanks
Steve
Old Aug 19, 2005 | 12:42 PM
Flamedx4's Avatar
You can, but it's not even close to the same. It's only textured paint really, sure won't help protect against heavy scratches or dents. Also you would want to be sure and check the type of undercoating - some of it dries hard and some stays kinda sticky forever... Undercoating is probably not the right stuff, you probably want texture paint - they make some for lower body panels to texture them and cushion against rock chips. You can get it in spray cans. But either way, it is not similar to rhino liner or lineX or whatever, but it's way better than nothing. That's what I have - see pic below. (lousy pic, best I could find)
Old Aug 19, 2005 | 12:43 PM
4x4Lamm's Avatar
I wouldnt, too soft and easily torn. Try Duplicolor bedliner, its cheaper than Rhino.
Lamm
Old Aug 19, 2005 | 03:03 PM
JEDI87's Avatar
I tried it on an old bed of mine and it gets relly soft in sunlight and rips off and leaves a nasty residue on the bed.
Old Aug 19, 2005 | 04:29 PM
pat2724's Avatar
Thanks guys I think I will pass on undercoating.
Old Aug 19, 2005 | 05:09 PM
phorunninduke's Avatar
The duplicolor stuff is not too bad for $50. A gallon is plenty btw.
HotNotch
Oct 8, 2015 06:51 AM
JaredL
Jun 16, 2015 04:47 PM
Ghostrider
Jun 29, 2005 04:18 AM
Highland Runner
Jun 16, 2004 11:08 AM
