U Joint going bad ?
Old Feb 26, 2010 | 01:30 PM
Elton's Avatar
U Joint going bad ?
started noticing a small vibration a few days ago but now its a little worse i know my cv's are gonna need to be replaced ...but i don't think that's the problem its most noticeable at above 35 under power all the way to 60 but if i push in the clutch it goes away and if your in 2nd and your slowing down it shakes pretty good
Old Feb 26, 2010 | 01:34 PM
brian2sun's Avatar
When mine started vibrating like that a while back, it was the rear u-joint. It had obvious play in it when I grabbed the driveshaft.
Old Feb 26, 2010 | 01:51 PM
Elton's Avatar
i hope its the u joint and not something i cant afford to fix right now it has a little click if u listen for it so that's why im leaning towards a u joint
Old Feb 26, 2010 | 04:16 PM
turboteg95's Avatar
kinda sounds like what mine is doing, also when i brake to a complete stop then let off the brake i feel a little "thunk" in the back end?
Old Feb 26, 2010 | 10:09 PM
brian2sun's Avatar
Try greasing the zerks first.
Old Mar 7, 2010 | 02:17 PM
Elton's Avatar
now its clunking
Old Mar 9, 2010 | 10:22 AM
Ritzy4Runner's Avatar
Park the truck and block the wheels. Put the vehicle in neutral. Crawl up under your truck and grab the drive line near the u-joint with both hands. Attempt to move the shaft either up or down/side to side depending on the location of the u-joint cross bearing and see if you feel any movement. If the u-joint is worn significantly you will feel the movement and may even hear the contact of the bearing surface in the u-joint. Check both front and rear u-joints for movement. Never have had an issue with a u-joint in a 4runner but I did in my old first gen Bronco. If it is really worn to the point you can hear the clunk-clunk of the u-joint, you will be able to feel the movement of the u-joint when you try this. Like was mentioned the sound is predominately when you are slowing. Centrifcal force helps to keep this noise and movement to a minimum when the shaft is spinning at higher speeds. When you are slowing to a stop you will be able to hear the clunk-clunk and a final CLUNK when you stop. Gravity works! Good luck
Old Mar 10, 2010 | 12:53 PM
Elton's Avatar
o ya now its done s63.photobucket.com/albums/h154/Eltonh/Toyota/?action=view&current=MVI_1658.flv
Old Mar 10, 2010 | 12:55 PM
vital22re's Avatar
totally a bro
OUCH TOWN population you bro!
Old Mar 10, 2010 | 01:00 PM
DeathCougar's Avatar
Why would you let it get that bad? You knew 2 weeks ago what was wrong....
Anyways, take that driveline out and get it to a shop so they can replace it before you explode the yoke. Or, buy a good used driveline.
Old Mar 10, 2010 | 01:04 PM
Elton's Avatar
lol im gonna fix it tonight since i have time now
Old Mar 10, 2010 | 02:07 PM
Call Maz-Toy auto recycling in Troutdale, they have a driveline in stock
Old Mar 10, 2010 | 10:13 PM
Elton's Avatar
20 dollars later good as new
Old Mar 10, 2010 | 10:37 PM
99 sas runner's Avatar
why buy a new drive line for a simple u joint????
Swim
9
Jan 4, 2016 10:47 AM
rustym
Aug 7, 2015 10:39 AM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
